(HELP) New Build Not Working
alpha29
Hi guys,
Just finished building my PC. However, it does not boot.
Symptons are as follows:
1.) Case LED works
2.) Case fan spins (connect directly to PSU)
3.) Graphics Card Fan Spins
4.) CPU Fan not spinning (Spin for split second and stop)
5.) Can hear that HDD is running
Any ideas?
Coolman
Can tel us wat u buy, everything.
oso take a picture and show us how it was assemble.
zenniz
There are many possibility.
Here is what you can do.
1) Plug the CPU fan connector to another fan pin header.
2) Skip this step if your case fan has no 3/4 pin header connector (Not molex connector). Plug the case fan connector into the fan pin header that your CPU fan connector previously used.
3) If your CPU fan is still not spinning, 60% chance your CPU fan is faulty. If your CPU fan spin, your mobo's CPU fan pin header might be faulty.
5) Skip this step if you did not do step 2. If your case fan spins, 90% chance your CPU fan is faulty.
alpha29
OK, I managed to resolve it. But its silly, what I did was I manually spinned the fan for like 10 rounds. Then I turned on the system again.. Perhaps something stuck....
jtjt00
New CPU HSF fan got this turning issue?
alpha29
Its a i7 4790 that I got from Amazon. Could be an isolated case though.. And at least its working now.
