help new ssd slow write speed
pointstars
hi,
might need some help from bros here, it goes something like this.
i cloned my failing hard disk to a brand new ssd yesterday. everything was ok, os able to boot, all apps able to run properly.
but when i ran a benchmark using crystaldiskmark, all my write speed was less than 20mb/s !!!??? , except for seq write speed. the ssd iam using is the same one as below.
https://forums.hardwarezone.com.sg/pc-gaming-382/hands-transcend-ssd220s-%96-affordable-upgrade-solution-gaming-5626511.html
my write speed is not even close to the ones in the review :sad:
should i rma the ssd or its user problem?
thanks in advance!
ZrE0_Cha0s
hi,
thanks in advance!
And what's the new ssd u using?
ZrE0_Cha0s
and what about your system configuration?
next are u using any old system btw? like SATA 1?
pointstars
my motherboard is intel h110m, cpu is g4560, 8gb ddr4 ram
the motherboard comes with sata 3, 6gb/s transfer speed
Koenig168
You should do benchies on an empty SSD. I suspect you are doing benchies on an SSD which is almost full.
wwenze
If SEQ is meeting specs but the rest are not is most likely configuration issues...
wwenze
BTW you said you cloned your HDD... is your old HDD from the old 512bytes sector era??
wwenze
Oh god...
Reinstall your Windows 10
And don't tell me it is still on Windows 7 please
it_geek
you might actually need to defrag it if you <strike>need</strike> (EDIT: did) a low level clone over. Cos all the pieces are still in the same places. This is the one and only time you should do it. This explains a fast seq R/W but a slow R/W access speed.
pointstars
you might actually need to defrag it if you need a low level clone over. Cos all the pieces are still in the same places. This is the one and only time you should do it. This explains a fast seq R/W but a slow R/W access speed.
will give it a go, hope things improve
