help new ssd slow write speed
Phen8210
boot in safe mode and run the benchmark.. maybe ur system using the hdd resource.
kracie17
perhaps a quick check. you might want to try changing your sata cable and also the port.. you might want to check your bios whether AHCI mode. just google your motherboard model and AHCI. by default it should be AHCI .
singupingu
Back up your read write stuff and reinstall windows and all your other softwares, update chipset drivers too.
Tedious and time consuming, but effective solving most problem.
Sent from OnePlus ONEPLUS A3003 using GAGT
terry1
i take every opportunity to reinstall my windows OS. installation takes only 10 minutes at most especially on ssd. it is only painful to download the hardware drivers but all the hardwork is rewarded with a very fast windows setup :D
pointstars
a quick update, finally sloved the problem by reinstalling windows. and of course all the drivers as well :( more of a user problem ha.
thanks all bro for the inputs.
would highly recommend this budget ssd to anyone loooking for an upgrade.
