help! stuck in boot loop!
TechNuB
Reseat rams gpu hdd all dont work leh.
What could be the problem any 1?
It all reboot by itself when i was gaming. Before it reboot, it was very laggy. As in stuttering every few sec.
Thus i reseated the rams and gpu. Den the problem began
Any gurus can help?
Thx in advance!
jtjt00
Try use minimum modules to troubleshoot, remove the following:
1. GPU, use onboard
2. use 1 pc of ram, swap if fail
3. disconnect dvd writer/data hdd/usb device other than KB/mouse
TechNuB
do you have the PC Beeper speaker connected?
any beep codes?
nope no idea what that is and dont hear any beeps
1. GPU, use onboard
i tried using onboard gpu too but even after removing my dedicated gpu, the problem persist.
i only have 1 pc of ram. already swap the positions. still dont work
now the time between booting and rebooting is even shorter:(
i highly suspect its the gpu tho.
theres 2 power lights at the 2x6pin power connectors for the gpu
it use to light up when theres power, even when its shutdown.
but now it only lights up when i press the power up button...
TechNuB
Maybe PSU.
what can i do then?
i m not actually sure which component has issue
so do i have to dismantle the suspected defective component to individual distro to check? or is there a easy way out?( dont tell mebuy new rig ah plz. mine only 22 months old:()
localITguy
Suspended
what can i do then?
did you connect this to your mbo?
setiardi
With all SATA devices disconnected including SATA power cables and GPU removed, try clear cmos/bios.
I had a faulty GPU causing the mainboard to be unable to start even after removing it. Only after clearing CMOS/BIOS located on mainboard did it able to start.
Can try lah.Good Luck.
