*adiBOY
- Mar 5, 2008
My info should not represent actual performance because I never plug direct to wall socket. I plug to the extension power bar because I don't have a long enough lan cable. If it is plugged direct to the wall socket, it should be faster. Current setup:
From router: Router > homeplug 1 > wall socket
To computer: wall socket > extension power bar > home plug > computer
I am using the sineoji 1800 homeplug, on M1 300mbps. My speedtest is about 140-150mbps download, 110-120mbps upload.
But yes it is stable, no spikes etc.
Able to achieve half of your subscribed speed with extension bar is good enough. Thanks for the info bro.
