Help with PC build?
Gymrat76
Hi all
Been quite out of touch with whats hot and what's not in the hardware world.. need to build a PC for my wife (I figured more bang for the buck than buying her a laptop). Her main use for it will be:
-Watching movies (streaming off the net & downloaded)
-AutoCAD when she brings her work home
-No gaming
Budget around $1-1.2k. Don't need monitor, keyboard, mouse, probably fine with onboard sound too.
Requirements:
Need at least 8GB RAM (for AutoCAD), maybe recommend a decent (but not expensive) pair of desktop speakers. Will need Win7 OS as well. Was thinking of just a 128GB SSD for the OS drive, I got spare HDD's she can use for data. Thanks! :)
melovelinux
Sharkoon VS3-V Blue +
FSP HEXA 400W - $99(BUNDLE) ( Based on Website )
Asrock B85M-HDS (BUNDLE)
CPU Bundle*LGA 1150: i5-4430 B*UNDLE - $348 ( Based on Website )
Kingston 8GB RAM ( 2X4GB) - $76 (Based on price list)
OCZ Vertex 4 SSD - 128GB $199 ( Based on price List)
Microsoft Windows 7 Home Premium (64 bit) - $116 ( Based on Website )
Total $ 838 + Delivery
Taken from MyNextCom
royfrosty
Hi all
-No gaming
Requirements:
Autocad to me i have been using it for quite some time, dont think it needs a very high cpu. It doesnt use hyperthreading. Agrees 8gb ram is needed. But to see things clearly and illustrations design i would recommend a gfx card.
Mobo+cpu
Msi b85m-e33 + i5-4570 ~ $341
Ram
Kingston value ram 8gb ~ $78
Hdd
2tb seagate 7200rpm ~ $110
Ssd
Plextor m5s 128gb ~ $139
Gpu
Gigabyte gtx660 2gb ~ $281
Psu
Fsp raider silver 550w ~ $78
Chassis
Xigmatek xp pro $58
Os
Win 7 home premium 64bit ~ $115
Total just nice $1200 without the ODD. Add $22 for ODD
Build at tradepac, can ask for further discounts.
bhtan83
autocad only utilize single thread and opencl, so an APU 6800K is more than enough for her usage and very bang for the bucks too.
wuweiz
Hi all
-No gaming
Requirements:
Up your budget. Autocad needs i7..
royfrosty
Been using it everyday on my own system. No lags at all. Btw im using 2012 though. Used in coy core 2 duo cpu also no issues at all.
Felfirez
Mobo+cpu
Ram
Hdd
Ssd
Gpu
Psu
Chassis
Xigmatek xp pro $58
Os
Remove the GPU, just use IGP. No need HDD as TS already have it.
i7-4770 & Asrock B85M Pro4 more recommended. Autocad doesn't need i7 but it does make use of hyperthreading. PSU down to FSP 300W.
All changes will deduct more than $100 off the total price and better suited for TS's wife's usage. Maybe you can spend that extra for a nicer chasis.
wuweiz
Nzxt 210 white $65+ only. :x
royfrosty
Re-edit
Forgot about the hdd part
Drop the hdd since you have an extra one.
To go igp or to go with gpu. I would say stick with the gpu.
I5 or i7. I5 will do even if it needs hyperthreading, it doesnt really make use of it. There is no great impact on it. Given with ts budget i5 is enough.
Overall save on hdd will be $110. So it will be $1090.
My recommendations still stands. Been using autocad for my engineering years. Never once i see a coy would use an i7 for autocad. Except for laptops user then yes.
Gymrat76
Thanks everyone for the recommendations! You guys are the best :)
Will go check out the models stated and decide on a build. Thanks again!
Ark Law
CPU+Mobo: i7 4770 + MSI B85M-E33 - $472
RAM: Kingston 4GB x2 1600 valueram - $84
GPU: onboard
SSD: Samsung 840 120GB - $140
PSU: FSP 300W - $39
Casing: Antec VSK4000-B - $40
Speakers: Edifier M1360 2.1 - $36
OS: Win7 HP x64 - $115
Total: $926
tungsten2
GPU: onboard
PSU: FSP 300W - $39
Total: $926
Your power supply abit under power.
Haha........but yes Autocad need an i7
royfrosty
just CPU and a few peripherals suck more power than 250W meh?
250w is not a true power. It is definitely less than what they provide. And definitely not enough if its not even silver or bronze standard.
Ark Law
I know it's not true power, but the entire system would rarely breach 200W at full load right? Hence the FSP 300W
