Help with ram upgrade and how much?
skystopper
Hi, I'm planning to upgrade the ram on my Dell Inspiron 660s to 8gb ram.
Is it possible to just purchase one 4gb stick to upgrade on top of what I have, or is it really necessary to purchase a pair to upgrade? Also like does the brand makes a difference?
shadow84
Can show us pic of the memory tab as well? So that we will know whether it is ddr3 or ddr2..
I believe you can just purchase 1 more stick, but make sure the speeds are the same, otherwise the higher speed will be bottlnecked by the lower speed.
skystopper
Here it is.
So as long as the other ram runs on 1600MHz then it will do, regardless of brand. They won't like conflict with each other?
shadow84
Here it is.
Yes.. maybe one more thing to look out for is the latency timings... best is both are the same...
skystopper
Oh...okay thx.
Is it the best to purchase during an it show (e.g. upcoming sitec) or where else can I purchase.
Might be purchasing a pair, depending on price. I just need to take note of it being a PC2-12800, 1600MHz ram right?
shadow84
Oh...okay thx.
I doubt sitex do sell laptop rams... need go sls to get. But, make sure there isnt any warranty sticker on the laptop part whereby you would need to take out in order to install the rams.
Go download the pricelists and compare which shop is cheaper.
skystopper
Haha...It is a desktop.
Heard a lot of horror stories about sls.
shadow84
What OS are u using and its bit? If it is 32-bit, getting more than 4gb ram is useless since it is capped at 4gb..
skystopper
Windows 8.1. Its 64-bit. I'm planning to upgrade it because I'm using programs such as Autodesk AutoCAD/3DsMax.
shadow84
Not really. If the applications are only 32-bit, then each instance of the application can only access up to 4GB.
Then, that is application problem, not com problem..... nth he can do except to wait for more support...
