Help with Singtel VLAN tagging
Nitrile
I'm really a noob when it comes to this.
The presets in the router (RT2600AC) don't work so i'm trying manual settings.
What do i put in these boxes?
I only need to use Port 4 for TV.
TYVM.
Nitrile
Why don't get Asus routers? Preset all ok one : ) good performance also, you try my settings ok mah??
i switched from ac87u to synology
sick of asus
always got problem with it.. ac87u was especially bad.
iicecube
How come you need to do it in manual part when the above post already mention the tag and priority..
Nitrile
something wrong with synology firmware i think
VLAN tagging and ISP settings don't work with MIO TV.
solved it by adding a smart switch and doing the VLAN tagging in there.
Ted100
Hi Nitrile
Did you ever sort out your RT2600ac issue with Singtel?
Can I ask how are you liking the RT2600ac? Would you recommend it?
There is a sale at Storage Studio for $329 and that looks like quite a good price.
Nitrile
Hi Nitrile
Doesn't work.
Had to buy a managed switch and did VLAN tagging on the switch for my Singtel TV to work.
renfred89
Synology Rt2600ac does support vlan tagging since firmware v1.0.1-6007.
Synology even wrote up a guide on vlan tagging on its website. How can it not work?
Do note singtel tv needs priority 4 to work. Or else it won't. Make sure you plug the Singtel tv connection to the assigned ethernet port too..
Doesn't work.
Nitrile
Their vlan tagging interface is so basic. And there's must be something wrong with it. I know how to vlan tag. It just doesn't work with the synology interface. Gave up and bought a managed switch and it works fine.
Nitrile
Just saw a new firmware on 24 aug.
It says that IPTV not working in some instances have been fixed. I'll give it a go later.
Nitrile
Hi Nitrile
after reporting the issue to them in early july, the issue has finally been fixed in the 24 august firmware..
use singtel-others preset and singtelTV will work flawlessly.
guess i can get rid of my managed switch already.
renfred89
That's good to hear.. Or else I really can empathise with you the pain of getting something that doesn't really work..
Ted100
That's great.
How do you like the RT2600ac as a router? It's not too popular here on HWZ since a lot of people stick to the usual Netgear/Asus.
