Hisense Brand
blue666
All TV are the same. The difference is OS and after sales.
same as China car, do we still care? Even jap is importing China car
86technie
I am using Hisense TV part of Starhub bundle.
Why a lot don't use is because of brand.
Is same like HP, a lot use Apple or Sammy.
TV wise either Prism, Sony, Samsung or LG.
Hisense or TCL rarely people buy.
TCL TV are best avoided a lot of people are complaining their customer service is bad.
My Hisense TV wise so far ok, using VIDAA OS so not Google OS can sideload or install app.
VIDAA OS good thing is it start up very fast unlike Android takes a while.
So far ok but some may not like Hisense as it's extremely bright.
Need to tune the brightness and contrast downm
nonameless
Things not mean for durability and reliability can just buy if cheap , a 2 years usage or until warranty ends is already value for money. If u gonna buy a car then of cos don't buy CCP brands.
NintendoSwitch
I recommend LG or samsung?:)
I bought 65 inch samsung,now think should buy 75 inch instead.
I put at side wall inside master room:D
Exactly. You can never buy big enough. I bought 32" then regret it wasn't 40". Then I bought 40" then regret it wasn't 50". Then I bought 55" then regret it was not 75". Currently peering at my 55" tv used as monitor that has to upscale to 125% on 1080p because 4k 100% is too tiny from the distance I am looking at it.
chaiscool
Moi use 120" at 2.5m also moi think too small but it's already edge to edge liao.
NintendoSwitch
I think only direct brain implant will be good enough.
iu
Mecisteus
Are chiu sure Bro @AngelRomeo Shu Shu? Prism better than Hi sense?🙏🙏
He is a prism salesman.
You can see him promoting prism in the TV section.
I skip Hisense because they don't have Google TV anymore for lower size.
I have 2x TCL now.
