Honest feedback on p20 pro?
Nevereatrice
P20 pro pros:
Excellent battery life of 4000 mah
Excellent camera
Ui is snappy. Doesn't lag
Good build quality in the hands
Soc kirin 970 capable enough (can match sd 835 but lose abit)
2 years warranty
Fast updates
Service centre at somerset 313
Cons:
Resell value not really good
Resolution only FHD+
Design wise the solid home button with a notch screen weird combination (personal preference)
S9 plus pros:
Good camera
Display is excellent
Top soc sd 845 or the exynos variant (there's talk about exynos chip having severe battery drain but not the snap dragon chip)
Have 2 stereo speakers
Ip68 certified
Cons
Poor battery life (3-5 hrs soc)
The infinity display breaks easily
The build quality at the back feels hollow in the hands (my preference)
What does this means?
In terms of battery life, It's a trade off between display and battery
Excellent display will have poor battery life
Poor display will have excellent battery life
This can be solved by portable battery chargers. Personally I prefer display resolution above FHD+
But be careful about buying s9 plus. S9 with the Exynos chip have severe battery drain, as several articles have warned
Performance wise, don't worry huawei p20 pro is good. I'm still using mate 9 and it is snappy still
Battery life is good
Tuakong
Will it lag after awhile?
Looking for a backup phone and cant decide between the P20 Pro and the OP6
Between the 2 which is better though this is a Huawei place lol
Sent from Cubicle while I pang sai.... using GAGT
Tuakong
Are local banking apps and Ezlink compatible with the P20 Pro?
Samsung Pay is out though
loster
i switch from iphone and samsung to p20 pro.
love the phone. no lag or whatever and camera is great.
i using a 3rd party launcher for my p20 pro
OutBreak
Never buy Lagsung. They are known to lag after a few months.. Those people that said it never lag is still in denial..
Tuakong
Just traded in my ip7+ for a twilight p2pro
ukyo100
May be add on 2GB of Ram might help solve the issue of lag.. Heard 8 series still the same.. 9 plus improved... Anyway I'm using M10. Long time didn't purchase lagsung since after s5..
MikeCortez
i changed from note 8 to p20 pro and has been using for more than a month. loving the phone so far.
what i like about the phone is that it definately does not feel lag as compared to my note 8(which often does).
the camera is good and the batterg life definately is much better than my note 8.The charging is also much faster as compared to my note 8.
There are definately bugs like all china phone but i wont say its serious enough to make me regret my choice
all in all i have no regret buying this phone from note 8.
How's your phone now?
