Honor Magic V2
Ray1976
anyone finds the screen have a slight yellow tint
Nope. My display can display pure white. Check to see if you have Eye Comfort feature turned on. Look at he control centre first, if not, go into the settings and type Eye comfort in the search bar.
Ray1976
Read that the Honor Magic Pen (global version) has limited functionality compared to the China version. Can anyone? If its true, what are the features missing in global version?
Globe
oooh ... so its coming soon ... global version
Ray1976
For those who is on the fence whether jumping from Oppo Find N3 to Honor Magic V2 will regret about the camera quality. Here's a few sample I have shot at Marina Sq and Funan Mall.
[Note: All images are raw JPEG w/o any post enhancement]
I'm at level 2, Marina Sq when I took this shot. There were some CNY decorations at the concourse area. Took this shot at 2.5x zoom.
At Funan IT Mall yesterday afternoon. Captured this with Magic V2 with some moving shoppers and I'm on an escalator going to level 3. I just simply "point and shoot". I took it at 2.5x zoom. There is no blurry image as far as I can tell. The colors are punchy and well balanced.
Here's another shot at the mezzanine area at Funan IT Mall. I took this shot at 1.0x.
I would say the images turned out very impressive for a foldable this thin.
savior1
For those who switch off auto rotate function, is there a simple way to change from portrait to landscape without auto rotate on?
Samsung previously had a small pop up at the bottom panel if they detect u switched views to allow rotation.
savior1
I am glad to report that Samsung Notes is working well with Magic Pen on HMV2 :)
How do you download Samsung Notes on HMV2? I tried searching on Play Store and it says this app won't work on your device. Any suggestions?
glorygoh
Find N3 also have, but I don't think V2 have.. :(
Justbear
Does this phone display the videos from FB on main screen properly?
Globe
anyone can do a voice msg on whatsapp if it is in floating window?
cant seem to do it in close or open form
erniechua
Just wanted to update that SIMBA eSIM works on the Honor Magic V2. Tried it out ytd at the service centre and was all prepared to lose the $5 esim change fee but it worked. Even the staff there was surprised as it is not on the supported device list. =P
glorygoh
Want to know wat are the pros and cons in using esim?
Simba 5G wonky leh, basement carpark, lift, etc, network coverage xie jialat
erniechua
I have 3 SIMs now in my Magic V2. A personal line under ZYM (physical), a company line under Singtel (physical) & a travel line under SIMBA (eSIM). I will swap between my company line & SIMBA when I travel overseas for work or leisure, all in a single phone. =P
glorygoh
I tot esim occupies sim2, can't have 2x physical Sims and 1x esim.
Only 1x SIM & 1x esim only?
