Honor Magic V3
aw1007
Well,based on my experience, this cant be done in andriod based phone. Either 2 nano Sims, or 1 nano 1 esim at a time.
eyz
yah i just read it up and you are right, only latest pixel and s24 has dual esim capabilities.
so using a esim card is way better than storing esim profiles on the phone due to portability.
johnsonheng
i will try to get the china number then can see if i can use the satelite feature.
Bolivar
No point, satellite features are exclusive for Chinese carriers for use within Mainland China. Not global. Only useful if you stayed in China rural areas for extensive periods. Most Chinese do not even use this feature, this feature is good to have but not a must have especially if you reside in the city.
johnsonheng
If you use CM mobile u can sign up for a china mobile number by pay extra 5 dollars per month, what i am not sure is that will it will, as it indicate it in partner with china mobile and not china unicorn.
zobrak
anyone bought accessories for it already?
case?
screen protector?
slim or low profile usbc cable?
50W wireless charger?
silicon carbon battery powerbanks with 50W wireless charging?
yhw22
case?
screen protector?
I already got Huawei Powerbank 40W and 66W version. So more than enough.
zobrak
wired rate right? if wireless currently i could only find 20W. or you mean 40W wireless?
also best get newer battery as powerbank can be slimmer too.
so far i could only find silicon carbon battery gen 2 powerbanks, can't find gen 3 (the version in magic v3)
yhw22
