Honor Magic V3
dodongdodong
Let us not confuse our minds. The definition of thickness: the smallest of three dimensions length, width,
vibranze
When I was at Chengdu, the Honor salesperson told me dunno which version of OS upgrade will include Google apps despite it's a China set, not sure how true it is? If for China set, the OS included Google apps, does that mean Quick Share, Google Auto, etc will work?
perfectlight
Google Auto might not still work. the rest will.
dsclaymr
Sorry noob to chinese rom and GMS. Would like to ask even for the global version with GMS, will it run singpass and the local bank apps well? Do not know about the limitations, thankful if it can be shared here.
berber
Chinese rom usually no issue with bank or singpass apps as long as bootloader is locked. Typical common issues with chinese rom include: Android Auto, Google location history, Google rewards, Google wear os (there is a chinese version albeit abit wonky), Nearby share not supported, delayed/unreliable push notifications (usually can do some tinkering to fix but unintuitive). In short, go for global rom unless you are able to live with the above.
1982-1994
don't understand how this 80.2cm coming from.
maybe it's thickness x 2 + width.
in this case it's the same. magic v3 is only 92.4mm, with wider cover screen because it's less thick
V3-83.2mm
F6-80.2mm
Think we don't hold the phone unfolded upon walking but we hold it in folded manner
Whenever a manufacturer says it's phone is slim, I'd see the width too
Example like Huawei mate 20x
It is slimmer at 8.2mm but definitely not comfortable to hold it in the hand
Sorry ah I am not good in expressing myself
zobrak
screenshot_20240728_015249-jpg.51096
V3-83.2mm
F6-80.2mm
screenshot_20240728_015729-jpg.51097
lol we don't just hold by its width but it's height or thickness as well. which is why I've added the thickness. it's the same as samsung. for smaller hands, one can opt for smaller phones.
otts
V3-83.2mm
F6-80.2mm
the width is width mah. thickness we talking abt actual physical thickness, not A x B the value. anyways fold6 is narrower and still very remote control like. so in terms of usage its not as friendly as v2,v3,xf3 etc..
eyz
Nowadays, eSim issue can be easily solved by using 5ber or 9esim card. Converting esim into physical card anywhere at your own convenient.
even with esim card, there is limitation to use only 1 esim at a time.
with built in esim, one is able to turn on 2 esim profiles at the same time.
correct me if im wrong, as im recounting my esim experience on iphone.
