Honor Magic V3
doki81
a.. what's the correct steps to tap on bus ah?
I was surfing net, my bus comes
I fold back
screen back to home screen
tap bus
failed wor... always!
then I need to rescan again... behind long Q liao sia.
this is not the right way?... MRT can wor.
if using gpay..make sure your screen is awake or awake with unlocked...i no issue so far tapping on bus..
without unlock...just make sure screen is awake with double tap to awake feature.
Computeron
I using gpay... so by right, my steps are right, right?
don't tell me I need to power off then power on unlock again to tap
at lockscreen, izzit consider awake?
doki81
at lock screen...as long as you got double tap it to let it awake. if have full screen AOD ...then you might confuse your screen is awake.
when you first added your cc to google wallet, i think it will ask you whether you want enable the without passcode for transport. did you enable that?
final1
unfortunately, there is no double tap to sleep the v3's screen.
Computeron
Izzit off this one? Mine is on
yhw22
Anyway to do magnetic trace n crop a person in pic so can create sticker? Like samsuck? The auto in magic is not smart enough to let me choose the correct object out of all objects in the pic
someone asked, it is not available to Honor phone. Now it is for Samsung, Pixel and .......forgotten
disastrous
Anyone realise Dynamic Refresh rate not really dynamic and for web browsers all stuck at 60hz? Unless u change to “high”. Both modes indicate up to 120hz
eddy0505
On dynamic, my chrome is between 1-120hz (mostly 90), my Samsung is 1-120 (mostly 120)
