Honor Magic V3
Amuroraysg
need knock hard....just dont knock until glass break can liao..
need practise like this
images
aw1007
thewiseone
Anyone tried using Android Auto with this phone. It's not stable, apps like Waze keeps freezing and crashing. On the other hand Google Maps is fine.
InOrAn21
Dear all, i finally can review after a week of intensive usage. I am currently using v3 and fold4 together, Fold4 used to be my main phone, now it became my spare phone after i gotten v3.
Batt Life
I made a habit recently to turn on airplane mode when i go to sleep every night for both of my foldables.. what surprise me is that after i woke up, v3 batt life only dropped 1% while Fold4 dropped 5%. There was once i forgot to turn on airplane mode... v3 batt life dropped 8% when fold4 dropped 13%.. so turning on airplane mode during sleep is a way to save battery.. i also found v3 battery outlasting my fold4 in terms of gameplay.. i played candy crush on v3 for an hour.. battery dropped 3%.. fold 4 dropped 10%..
OS
Seems like i am having problem with Android Auto on v3 but none on Samsuck. But it didn't really bother me as i am using samsuck as my 2nd phone.. Still learning how to use Magic OS and thanks to the bros here.. learning makes easy. There are times when my magic OS will hang abit when using facebook but after i off the app and open again.. it works wonders..
Hardware
i have used samsuck fold 2 & 4 before joining the honor v3 family. All i can say is the v3 screen is big and light. the dream of having a candy phone size exterior screen and open up to a foldable big screen has come. Am grateful on how sincere Honor has given to their customers compared to Samsuck. The free inner case is awesomely good and the fast charge of 66W makes charging amazingly fast.
Conclusion
After using both foldables together, the sleek and slim v3 won my heart over the fold4. The long lasting battery life is another convincing factor for the switch. So for those who are still thinking.. don't wait anymore..
tohchr
Batt Life
OS
Hardware
Conclusion
My battery life before sleep at around 11pm is 100%. Wake up in the morning around 615am, still 100%. Because I define app launch all to off except for communications apps like Whatsapp, banking apps etc.. Those which u need not let it run in the background, just set to manual and turn off
- Auto launch (Turn off)
- Secondary launch (can leave this turn on)
- Run in the background (Turn off)
Hardware78
I was told by official honor store that if the screen protector for either inner or outer screen was removed, the 1 year warranty will be voided. Is this true? I saw someone mentioned that he had replaced the front screen protector
tohchr
I do not think this is true. Outside one should not be subjected to warranty issue. Inner screen protector might be but definitely not for outside.
yhw22
What app you used to control whether to let the application run in background or not?
Ray1976
A new firmware available (about 4.08MB)...more of a patch make the system more stable. I discovered a new multi-tasking app drawer located at the Most Recent app taskbar.
More importantly, the Google Play System update is now available - After update, it will have Aug 2024 patch.
tohchr
Under settings, App, App launch..
- Select manual for that app.
Then u will see the following selection.
For app which u do not want it to be running in the background, set it this way.
For app which u need notifications, set it this way.
