rebornsoul
- Nov 17, 2007
nope it doesn't.Does this required glue?
U got the link? I also want to change to TP. Thank you!nope it doesn't.
Where did u bought it? Using glue?Anyone using those nano glass protector on this phone? Just installed one, the thiness is like flim protectors but when you touch it, feels like glass
With black boarders? Stick to the screen? Or just stick to the sides.?nope it doesn't.
Is that the 光固非菻膜 ?Anyone using those nano glass protector on this phone? Just installed one, the thiness is like flim protectors but when you touch it, feels like glass
I guess so since it is marketed as "UV Nano Glass" and it uses UV to cure which is what 光固 meant.Is that the 光固非菻膜 ?
Yup ..am using one. Nice feeling,smooth like glass..Bought it at NEX mall L4. Not using glue. It pastes like a hydrogel/flim protector, paste, peel off the top part, then it gets sent for UV curing for a few minutes.
Which store at level 4? There's like 4 or 5 storesAnyone using those nano glass protector on this phone? Just installed one, the thiness is like flim protectors but when you touch it, feels like glass
Does this protect against drops? Whether with case or withoutBought it at NEX mall L4. Not using glue. It pastes like a hydrogel/flim protector, paste, peel off the top part, then it gets sent for UV curing for a few minutes.
Better see review pics next time bro lolJust rec my TB hydrogel so.. Wa lan.. Got black boarders de.
Front case also came... Sides n bottom got recess area. Abit turn off.
Bad haul for this batch of purchase... Don't think will use them.
Now reduced to 2 le haha... I think its called banana story or somethingWhich store at level 4? There's like 4 or 5 stores
I think in the first place, the front screen is curved glass so if you drop it at its edge, its most likely gone case anyway.Does this protect against drops? Whether with case or without
Got see... Didn't see properly tat black boarders.. Didn't know hydrogel got boarder too.Better see review pics next time bro lol
Hydrogel flim got black edges is pretty damn lol/scammy manGot see... Didn't see properly tat black boarders.. Didn't know hydrogel got boarder too.
Just ordered another batch of tg n front case.
if you drop it flat without front casing I think it will protect in the same way as TG.
Rhinoshield website has a page to talk about such plexiglass screen protectors
https://rhinoshield.co/blogs/all/po...zdtO2p1xUmQFGqkAFt-O2o1FbGQW285tMxYuoLtW7ODlx
I guess it depends on how hard it was dropped.Interesting, can probably try if my TG cracks. I'm a loyal TG fan. My previous OnePlus 12 with cheap uv glass TG and bumper case didn't even crack despite much abuse, dropped from heights, smashed against wal etc. Very durable.
I found these on Ali.The v3 is a good phone, easy to hold on the hand as compared to Find N3. But the incoming call is a bit soft as compared to Find N3.
Any recommendations for case similar to the one that comes with the phone? Thanks.
How much?Bought it at NEX mall L4. Not using glue. It pastes like a hydrogel/flim protector, paste, peel off the top part, then it gets sent for UV curing for a few minutes.
