Honor Magic V3
Kelvin0217
This one looks good, claims to protect against drops as well. The SP feels more like glass or hydrogel or? Can consider trying once my TG cracks or wears off.
feel like hydrogel. It claim to be better than hydrogel and temper glass.
doki81
I have also bought this back skin which is a bit thick but easy to apply.
【淘宝】限时官方立减3.6元 http://e.tb.cn/h.gHNLNdMsL0Y6YuF?tk=cjBN3jF7OzX HU7632 「荣耀magicv3撞色素皮膜荣耀magicv2后膜荣耀Vs3背膜荣耀MagicVs2手机后膜素皮贴至臻版后盖保护膜」
点击链接直接打开 或者 淘宝搜索直接打开
I bought the same which deliver this morning 1244am...but the SP has black edge..still thinking to paste or not. I also bought the privacy screen edition.
keithlim
My screen protectors from TB are here today. This screen protector is easy to paste as it comes with a casing for installation. No bubble and dust at all. Those interested, can take a look.
【淘宝】限时官方立减3.7元 http://e.tb.cn/h.gHi35dYGMGJsvdj?tk=wEQW3jF63CI HU9196 「适用荣耀MagicV2防窥膜MagicVs3防偷窥外屏钢化软膜honor新款折叠屏前膜V2至臻版全包昆仑手机膜华为全胶贴膜」
Mine came as well! It was easy to install and looks good.
keithlim
This looks good! How's the feel of this skin? Does it add friction? Attract fingerprint?
doki81
the front casing double sided tape really leave a lot residue after take off... :oops:
doki81
i bought the privacy version and a piece of extra on clear. installed privacy version..the screen look like not as sharp as before. :(
application is smooth and no bubbles at all. will use a while and then see if want to peel off and apply clear version :oops:
Computeron
Ur screen now is 720p lol
eyz
【淘宝】限时官方立减9.8元 http://e.tb.cn/h.gHO1jzyiUjYRbuZ?tk=yTaw3jzbjJS CZ0016 「新款中轴适用荣耀Magic v3手机壳凯夫拉magicv2芳纶碳纤维全包保护套VS3超薄磨砂硬壳商务高档简约防摔男士潮」
i used this brand of casing for my v2. it comes with the custom screen protector for the front casing, and it is very well fitted. the front casing need tape to secure. never encounter tgsp popping up or seeing air bubble entering.
the rear casing with hinge protector has the option with magsafe too. it comes tape, which i dont use, and it is still very secure. makes removal of sim card quite easy.
the set comes with 3 tgsp, which i had used only 1 so far. love the thinness of kevlar.
this is my experience with v2, v3 quality and standard may vary.
rchow2008
Just applied my TG SP, front case doesn’t fit now 😞 Will use without front casing for a bit to see how it goes. If I don’t like it’s back to hydrogel SP.
doki81
i took off my front case after apply the taobao xit sp... havent try to put on front case yet.
my benks fiber case should arrive today. will try with benks fiber case.
Computeron
if the TP SP is same size as the screen.. confirm front case won't fit... TP got thickness
doki81
the one i pasted ...from taobao...is not really full screen..can see have some space around 4 corners.
NeonX
Those looking for grip, the tango thin grip from Amazon US is quite good. Thin and not bulging. Easy one hand deploy
