Honor Magic V3
Computeron
I applied the Imak glass protector.. so far ok. glue i think its just the outer rim only. I managed to squeeze the front carbon fibre case as it is a thin case.
gd for u bro... got pic?
eventhou I have the CF front, I didn't put... cuz the original front from honor, got contour lines/slopes.... CF one all r flat, which somehow makes the case looks thick.
no 1 order those tthin adhesive tapes for the cases? TB got sell 1 pack.
doki81
the benks fiber case with the add on benks magsafe ring is quite good. can open up center to use like pop socket.
doki81
zaphien
Hi, just to check Honor V3 can't fit Huawei X5 case right? There is a design that I like meant for X5 but not available for V3
Ray1976
Note that the new translation features are already available for the Magic V3 global variants. Although the company is now bringing them to the Chinese models. Regarding the other changes, Honor may soon roll out these enhancements for global Magic V3 users.
Yes, if you read in between the lines, you will realise that the so called .173 version is meant for China Rom which is currently on .162 iirc. For global version, it will have a different version number I believe. Clearly Honor is not following the same naming convention when it comes to Rom release for 2 different markets.
Ray1976
Huawei and Honor do share similar design language...so not a surprise if Huawei case may seem to fit Honor as well.
doki81
My benks case arrived today. The case is slimmer than the original by around 1mm.
are you still on your benks case? do you notice...the inner screen now have a weird fold in the center? the crease suppose to be a U and now become a W?
anyone can help confirm if your inner screen crease is more to U than W?
Justbear
netflix - full internal screen
amazon prime video - not full internal screen
youtube - not full internal screen
disney+ - ???
tiktok - ???
those who have problem with screen protector for the external screen can go to tech house at novena square for custom cut SP (hydrogel). $27.90. That's where i did mine.
This v3's external screen does not seem ideal for tempered glass type SP. Reminds me of years ago when i had a Samsung S10 with also curved screen.
Full internal screen, does it means the image is cropped ?
Computeron
Need ur image to better understand wat U and W u talking about
I mean look or touched?
