Honor Magic V3
doki81
Need ur image to better understand wat U and W u talking about
I mean look or touched?
er....look and touch..instead of a U...now i notice my internal screen centre crease now more like a W...
Computeron
I'm seeing 2 deep lines.. N 2 faint lines outside the deep ones... Is this W?
Feel I still U
NeonX
Chinese folders tend to have W crease of that's what you mean. W crease less noticable in the longer term compared to Samsung style U
zobrak
don't worry so much as long as you never put two layers of screen protector or slam the phone like laptop
Ray1976
are you still on your benks case? do you notice...the inner screen now have a weird fold in the center? the crease suppose to be a U and now become a W?
anyone can help confirm if your inner screen crease is more to U than W?
Take a pic and show everyone here. It's unlikely that a case can do something to the inner screen.
NeonX
Slight disappointed in the benks leh. Feel like using naked haha
doki81
i am using front naked. i try use the honor free case front part..seem like it's compatible with benks. so far my xit tabao privacy screen seem working fine too.
speak too early...the sp lifted on the bottom...have to took off front case now .. :(
NeonX
I just stick a magsafe ring directly onto the phone, gonna use naked to try haha
doki81
Raw is war! I weighted the benks case Vs my black case...benks is heavier by 0.02g...no wonder feel it's a bit heavier...
Seanthesheep
Honor shopee site shd have the link...where you bought your v3 from?
Bought it from Best Denki. There is a warranty card in the box with QR code that leads to eplanetworld warranty registration site. however the form on that site doesn't show up properly. I only see a save button
Computeron
My new batch of TB just arrived.
Another lousy front case..
The smaller tg sp.. Fit is gd.. But quality not so. Bought 2, first one applied spoiled.. 2 nd one also not perfect... Fk forget it.. I'm so done
rebornsoul
Have to take back my previous comments about the Imak screen protector being good. It's bad and the right side (curved side) is not adhesive anymore after 1 week, have problems registering my touches. Removed it and installed Benks tempered glass which is much better now.
The Imak also had wierd clarity and reflection issues. The Benks is like whitestone but whitestone is still the best with uv glue installation. The Benks uses traditional adhesive and is quite hard to paste properly, suggest ask shop to install for you.
NeonX
for screen protector, the best still probably UV nano glue one. Buy from TB self apply, so far so good
the one at nex is self printed, quite interesting the machine, if got a lot of devices probably worth it to get the machine haha
eddy0505
Told you guys to use the same kind of UV glue TG that I sic-ed liao. $3 cheap cheap still using now.
zobrak
if you buy the black version, it's lighter. plus there's no need for hinge protection
