progene
- Jul 17, 2005
This question always Pop every now and then... Ppl always confuse with this...Honor is very similar to Huawei but with google. Full stop..
Both working fine for me.If download douyin then OCBC app cannot use and states malicious software detected.
I downloaded from hereI went to official Douyin website to download. Would you be able to share the link here? Thanks !
May I inquire why you want to download the Chinese version of TikTok? Any benefit over the latter?Anyone knows how to install Douyin apk on this v3? It said the phone is not compatible. Do I need to disable something before it can install apk?
You go do the tryout ver.. No need screenshot..Curious about the giant bar you guys are talking about.... Any screenshot to share?
GreenHi can check those buy green colour does the original case also green or black ?
Most contents are from china. Many china chio bu.May I inquire why you want to download the Chinese version of TikTok? Any benefit over the latter?
LoL I also play to see China chio busMost contents are from china. Many china chio bu.
All use mei tu x100 ...sigh..like seeing all the Korean bu..all same face.LoL I also play to see China chio bus![]()
美图吧Most contents are from china. Many china chio bu.
Mine also this. I don't think is glass... Too thin【淘宝】限时官方立减11元 http://e.tb.cn/h.gFlPwVpHVfgKMFd?tk=SOBD3Ph8zC7 CZ0012 「【3D热弯曲面膜】特好拉适用荣耀magicV3全胶钢化膜华为magicVS3折叠屏手机膜V2至臻版huawei全屏覆盖防摔」
点击链接直接打开 或者 淘宝搜索直接打开
Hi all i bought tis tg screen protector and its good.. sticks whole screen not the sides only and can fit our original case. No need to use glue and uv light too. Juz stick on.. Will wait a few days see the sides will come out not haha . So far so good v oleophobic and clear..
But before i pasted it i tried to fold it its hard. Shld be glass.. hahaMine also this. I don't think is glass... Too thin
I consider as hyrogel
