I manage to found a video to teach on how to circle to search.no, u know samsung circle to search? same thing
the latest software is 175 not 155, try press the tryout version to get 175.I have updated to software v 155. Previously I created the shortcut for the face to face translation apps. But recently it's gone. I tried to add it back and it says the shortcut is added. However, I can't find it on the phone. I do a search on phone also can't find. What can I do?
Yes.huh must press home button de ah? cuz I using other launcher wor...
Thanks for the enlightenment! Does it mean I can only see the f2f translation apps only in standard mode? In drawer mode, I can't use it as I can't find it.the latest software is 175 not 155, try press the tryout version to get 175.
as for the shortcut, did u change ur home screen style from drawer to standard? if yes, change back and the shortcut will appear.
yes, if u wan change to drawer mode, delete the shortcut first on standard mode first den when u switch to drawer mode den u go add the shortcut again.Thanks for the enlightenment! Does it mean I can only see the f2f translation apps only in standard mode? In drawer mode, I can't use it as I can't find it.
pre order 1st batch ladybosswhere u get this price?
Forget about Xiaomi Mix Fold 4. It's meant for China market only. Of course you can import one if you want. Get the V3 instead.Sorry to off topic. Anyone has any thoughts on Xiaomi's mix fold 4? I don't see it on Xiaomi's official store.
Just hide itAnyone know how to revert back top bar size? Don't like so big leh![]()
Open google play store, click on your profile on top right, select play protect and then turn it off. After installing completed, turn it back on.Anyone knows how to install Douyin apk on this v3? It said the phone is not compatible. Do I need to disable something before it can install apk?
Oh, u might have downloaded a wrong version. I had 抖音 installed as well..Still can’t install after I turned it off. It still says “ App not installed as app isn’t compatible with your phone.”
The longer way is settings>assistant>yoyo assistant>f2f translation.Thanks for the enlightenment! Does it mean I can only see the f2f translation apps only in standard mode? In drawer mode, I can't use it as I can't find it.
I went to official Douyin website to download. Would you be able to share the link here? Thanks !Oh, u might have downloaded a wrong version. I had 抖音 installed as well..
I tried and have same issue alsoStill can’t install after I turned it off. It still says “ App not installed as app isn’t compatible with your phone.”
