Honor Magic V3
doki81
anyone can intro place to replace screen protector (outside)? i just dropped face down while folded.. screen is fine (very impressed), but the original film is tored.. so looking to change the sp.. not looking at diy cuz i cant change ffs:censored::censored:...
are you using the free front case?
tohchr
Try Tech House @ Causeway Point Level 3.. Fibre glass type which is cut out on the spot, cost like $30+.. Or u can google for other outlets of Tech House in SG.
doki81
fibre glass?? or hydrogel??
just get the taobao hydrogel easy apply..no need skill..just need to ensure you wipe off all the dust...turn off fan..
it come with a chamber to apply.
but it's not compatible with case.
zobrak
cause i got some devices on SG server some on CN server ...if i need to make changes to any of them need to switch lor ...was thinking if i can have 2 separate aqara apps then no need keep switch servers
yes you can. just run second aqara app in either private space or parallel space
Ray1976
Nobody knows...some of the global AI feature rolled out to global ROM first, then followed by China ROM which received the face-to-face translation (as an example). I agreed with both, the AI feature availability can indeed vary based on the locality.
