Honor Magic V3
wildpig8
I'm using Macrodroid. You can get it off Playstore. There's a free trial with limited Macros but if you only need one routine, it should be good enough and you don't need to purchase.
Download another app called gestures and you can also set it to swipe up from bottom screen to launch Gpay. Once Gpay is launched, Macrodroid will turn on NFC. Once closed, NFC will turn off.
Thanks!
wildpig8
Is V3 able to set up 2 different wallpaper? 1 for internal screen home screen, 1 for external screen home screen?
I have tried, but seems like home screen wall paper is share between internal and external screen.
Am i right?
yhw22
https://www.hardwarezone.com.sg/fea...yXRcF4z&sc_llid=62879&sc_eh=6940d7199fdcb9c81
Top 10 reviews......V3 made it last spot. lol
Foldable smartphones have gotten plenty of interest over the last few years, and brands are now rushing to make their offering the thinnest and lightest while not skimping on performance, battery life and photo quality. In our opinion, the brand with the best results so far has been Honor, and their Magic V3 foldable smartphone is the epitome of that at just 9.2mm thick when folded, making it the thinnest foldable smartphone on release. It also performed admirably in terms of battery life, performance and cameras, so we can understand why this piece made it into our top 10 reviews for 2024.
madhero
Am i right?
Doesn't seem possible.
rchow2008
anyone using those front case with SP embedded? how's it? izzit reflective?
Yes, using one where the SP is built in to the front cover. Quite reflective. Keeps the profile as slim as possible though. But also I feel it reduces the sensitivity of the touches. Especially in the corners, feel I have to tap a bit harder to activate the screen! Changed back to a hydrogel SP now. Much better.
thewiseone
Used one case with the same experience, sensitivity was terrible at the corners. Turns out it's due to the top cover that's not properly designed to sit securely with the phone. Changed to another case with a built in SP and it was so much better. No issues at all with touch sensitivity throughout the screen. Only issue is the reflective screen that doesn't really bothers me.
Computeron
I c.... ok think I don't buy liao... thx...
feel like changing case... but even TB also very limited.
madhero
OS9 out for local sets. Just updated mine.
kaiser_11
are we getting the fake/AI video detection feature of magic7pro?
I downloaded and installed as well. I don't think this feature and others are available yet. I would assume they will do another update to the software after Magic 7 is launched globally.
