Honor Magic V3
doki81
Region set had been getting MagicOS 9.0. when is global set turn to get it? Sian.
Not sure by setting to one of the region, can we set back to global again.
no..i try put my honor app to UK region or Msia also no different. won't get any update...
sallybee
is it or because it needs to unfold the battery so that its easier to charge via series than a parallel circuit?
yhw22
The Honor Magic V3 needs to be unfolded to charge because this allows for optimal access to both battery cells within the phone, enabling the fastest possible charging speeds; when folded, the charging process might be slower due to potential limitations in power delivery to the divided battery compartments.
Key points about the Honor Magic V3 charging:
  • Dual Battery Design: Foldable phones like the Magic V3 often have two separate battery cells, one in each half of the device.
  • Faster Charging When Unfolded: Unfolding the phone provides a better connection to both batteries, allowing for faster charging speeds.
  • System Notification: The phone may even prompt you to unfold it for optimal charging speeds.
DeepseaG1523
from Chat GPT? lol
pkchair
Any notification delays / no notifications from MS Teams, Outlook and Slack? I plan to use this phone for work so this is v important.
wildpig8
Hi! Anyone got any idea how to set up a routine to enable NFC when open Google wallet and off once i close the app?
madhero
I'm using Macrodroid. You can get it off Playstore. There's a free trial with limited Macros but if you only need one routine, it should be good enough and you don't need to purchase.
Download another app called gestures and you can also set it to swipe up from bottom screen to launch Gpay. Once Gpay is launched, Macrodroid will turn on NFC. Once closed, NFC will turn off.
tellim
I already self replaced the front screen protector. Only cost 2+$.
My inner screen already showing bubble at edge. Will hang on nearer to one year then go replace it at service centre....heard it's free?
doki81
Can honor service centre replaced? I using the original one purchased. Never change.
I rmb few pages back someone wants to replace outer screen protector and was quoted quite expensive at service center. I can do for you for 50% cheaper... 🤣 It's really just a 10 mins job.
lockks
What! It's not covered under warranty? Samsung one is.
