Honor Magic V3
yhw22
Does anyone use the wireless charger that came with it? I have a very slim case on and it just doesn’t charge very well on it. Anyone else have issues with it? I don’t want to remove the case every time I want to wireless charger.
I got no problem with the free given case when charging. Do you open to charge? If so, you must place it correctly, I knew it was a challenge as unbalance.
doki81
what do you mean doesn't charge well? please take note that wireless charging using honor wireless charger will be 55w instead of 66w by wire.
when you put the phone on the charger, did charger white light up and stable?
doki81
LoL part of the reason I jumped to V3 is because Samsung frequent green line issue after OS update. Now you tell me here also same? :eek:
non of my phone suffer this green line issue. i drop mostly once on each of them. LG V3...Sony Xperia....S22U...Fold 4/5/6, and now my Mi 10 Ultra all never get green /pink line.
yhw22
green line is all luck. some have some don't have. til now still dunno why causes it when updating firmware.
rchow2008
I mean the charge goes on and off a lot. I Move it around to try to get the perfect position, but it doesn’t stay charging. Not sure what’s wrong., but it doesn’t stay work when I take the case off. I’ve tried 3 different cases, seems to be all the same. Do MagSafe cases interfere with the charging? 2 of the cases are MagSafe.
hello123
green line screen issue for Samsung phone is very common . I have used honor V2 , X9b and V3 . so far no screen issue for me
doki81
ah..now you said about your case is magsafe...then should be the case that cause the issue. i have no issue with the carbon fiber case with magsafe to charge with the honor wireless charger.
but if i stick the magsafe finger ring on the case, then i won't be able to charge. must take off the accessories ring first.
Computeron
just installed a front case that came with SP embedded.
got dots.. but noticeable.. I think didnt stick to screen. bit reflective.
smooth like my armpit...
well, can't be bothered liao.. honeymoon period over for this phone.
just don't want my front screen to be so dusty... previous set up is hydrogel, ontop stack a front frame... walan.. all the sides catches dust.
yhw22
https://www.hardwarezone.com.sg/tech-news-honors-experience-store-at-causeway-point
Grand opening on 18th and 19th Jan.
On 18 January 2025, as part of the grand opening festivities, customers who turn up early can receive a free limited-edition Honor umbrella. This offer is limited to the first 100 customers
Relax with a free cup of coffee on the 18th and 19th of January. Note that there is a limit of 200 free cups each day.
Come down and enjoy in-store promotions on Honor smartphones. On the 18th and 19th of January, customers can receive:
  • Finally, for the entire roadshow, customers can receive S$100 off on the Honor Magic V3 (U.P. S$1,999).
tellim
Anyone inner screen protector starts to peel off? I heard only one time free replacement during one year warranty? How much to replace if it's out of warranty?
sallybee
can actually tear it out , and replace. the box that comes with the replacement usually have steps. quite easy to do
tellim
O didn't know there is instruction regarding inner screen protector.
Wondering if can remove the protector and just leave the screen as it?
doki81
Today plug in charger... suddenly saw this msg and my battery now showing 80% only despite wire plug in.
It's been a while since the last ota update and it didn't show and now it decide to show and stop the charging? 🤔
ignies
been eyeing this phone to replace my z fold 4, seems like cheapest so far is shopee with voucher ($1.6k).
ne here manage to get cheaper? fold 4 still working so no rush.
ahtom82
i also see cheapest is 1.6k with voucher. haha
using s24 ultra but this year feel wanna try to change to this phone instead and use. cause the weight is almost same as s24 ultra but is foldable and thickness is almost comparable with s24 ultra when it's folded....
i saw some selling china version online at cheaper a bit. is it worth it to get the China version?
stupidog
over 1k phone get with warranty safer
