doki81
- Jun 11, 2010
but but but....it's gonna be the same like fold 6..what's the point...charging speed still 15w...battery 4000mah..Ta han abit bit fold 7 liao
I suggest if can wait abit wait for oppo fold n5 first and see. Likely announcing this month.Guyz, i am currently using Samsung Fold 6 and this V3 actually attracts me in terms of the screen size and some of the features.
- is it a good idea for me to jump from fold 6 to V3?
- Is the OS stable and apps are stable?
- Is there any cons for this V3 as compare to Fold 6?
Been years already.how long you has been with Samsung phone?
I don't use the notes. Am using the samsung keyboard.. gallery wise , only use for sorting out photos into folders n maybe sometimes add text onto photo etc...If you can do without Samsung Specific apps like the Notes, keyboard, gallery etc, then V3 is a pretty good stand in. I have both currently and I've switched my daily driver to V3 just because of the bigger outer screen.
Ya or wait for this one then see howI suggest if can wait abit wait for oppo fold n5 first and see. Likely announcing this month.
You saw one video vs the majorityYa or wait for this one then see how
I saw one video fold 6 beat v3 in battery life wor... Lol
due to One UI very polished...problem is...win by a bit..but will take forever to charge full.Ya or wait for this one then see how
ya that very 1....You saw one video vs the majority
u can add the screen lock widget to home screen...Any idea how to tap the screen off instead of using the power button to turn off the screen.
Any setting need to be done?
Got it, thank youu can add the screen lock widget to home screen...
Use a 3rd party launcher or install a widget.Any idea how to tap the screen off instead of using the power button to turn off the screen.
Mine isn't so. I'm able to move the gallery and settings icon anywhere or place them in any folder. Maybe try clearing the cache of your Honor Home.Upgraded to Android 15 and somehow te gallery and setting icons are hiding inside the essential folder and can't bring it out. Anyone has any solution
No need install 3rd party. Stock magic os9 also have the lock screen widgetUse a 3rd party launcher or install a widget.
how to add the lock screen widget? is it under settingsNo need install 3rd party. Stock magic os9 also have the lock screen widget
