Honor Magic V5
eddy0505
This seems like a plus/S version of the original V3. Don't think it's worth it at all for us v3 owners to upgrade. For others maybe.
jacklim82
Actually really no point upgrade from v3 to v5..if only, they have overtrade program for the upgrade then can consider
maumu
Ditching your xiaomi 15 ultra ah?
yeah... 15 ultra is good but I really want to move on to a bigger screen for productivity purposes.
the camera specs on v5 is soooooooo much better than oppo n5 (which was why I had to pick up the 15 ultra).
too bad it's not practical to have both 15 ultra and v5...
eddy0505
Saw GSMArena got 8.8mm and 9.0mm version, so which colour is the 8.8mm version? Any ideas. Thank.
White color thinnest this time round. I think nowadays the difference in weight/thickness is if it's carbon fiber back- thinnest and lighter and usually black color. The rest is glass back thicker and heavier by 6-9g
maumu
anyone knows the actual sensor sizes of the three cameras?
the official spec is only for the 64mp zoom lens which is 1/2"... what about the 50mp main camera and 50mp ultrawide?
maumu
i'm quite tempted to get the white color just for the sake of the thinnest and lightest... but then I remember after putting the protective case, stick on screen protector... they'll end up heavier anyways.
so, will be aiming for the dawn gold color.
eddy0505
https://m.gsmarena.com/compare.php3?&idPhone2=12899&idPhone1=13982#diff-
Since x fold3 pro still has the best camera among foldable, I shall stick to it
Samsung fold 7....the slow charging speed and green line hold me back
If cameras are your priorities then you should stick to just vivo. Samsung is never gonna be good in the photography department even in their ultra flagships. If battery is your priority then Oppo N5 should be king even tho the 7 core 8 elite performance is about the same or worse than 8 gen 3.
eddy0505
From GSMArena should be this
50MP f/1.6 wide-angle camera, a new 50MP f/2.0 ultrawide (up from a 40MP unit), and a new 70mm f/2.5 telephoto with a 64MP 1/2.0-inch sensor (up from 1/2.51-inch).
yhw22
5000万像素广角摄像头(f/1.6光圈)
5000万像素超广角摄像头(f/2.0光圈)
6400万像素潜望式长焦摄像头(f/2.5 光圈) 支持激光对焦,支持后置色温传感器
50-megapixel wide-angle camera (f/1.6 aperture)
50-megapixel ultra-wide-angle camera (f/2.0 aperture)
64-megapixel periscope telephoto camera (f/2.5 aperture) supports laser focus and rear color temperature sensor
https://www.honor.com/cn/phones/honor-magic-v5/spec/
eddy0505
It depends on how adventurous you are..if you are gonna put on a non transparent case then any color doesn't matter. If you are yolo like me, I don't use any case for my honor v3 and vivo x200 ultra that's why I chose brown and red for the unique colorways.
maumu
sorry am asking about sensor sizes not f-stop values...
