Honor Magic V5
Waiiii
You can swipe up taskbar from bottom and launch floating windows from the app selection menu when in 3 split mode?? I can swipe from the sides for floating windows no issue but not from the taskbar..
can. but i think is because you switch off the turbo ram. maybe system not enough resource to support?
chari-men
Nope also crash when ram turbo was on...will do further testing on this but seems consistent at least for my case..
doki81
seem like v5 now even the charging speed is throttled. charging half way, saw a message to turn on turbo charging. you have the option to select turn on this time only or always on. but the system warn that it will make your device hot/warm.
phiber
Can we turn on Automatic call recording? Coming from a global vivo x200 pro which ahs this feature..
chari-men
Mine turned on all the time... Always charging folded.. the heat minimal at least in my case room temperature with fan..
1982-1994
Just on it ,enjoy these little things in life though can't rule out it might be one of the reasons to decrease the maximum capacity of your battery life
yhw22
did it warn you to unfold to charge? as v3 will warn u to unfold.
