Honor Magic V5
nuscape
Try sync your n5 with Google first and then use Google to transfer during the setup screen.
I already missed our the initial google restore part. Resetting again is not a good option now. I thought initially I can always use the clone app as I did this with oppo months ago. But apparently HMV5 clone app is not working.
Read HWZ Forum Rules!
chari-men
I've had some minor issues with apps not loading properly.. turns out the culprit is the ram turbo option enabled by default. I turned it off and the apps running well now.. and somehow feels the phone is so much smoother...
doki81
suppose 16gb is more than enough. when add in to use ROM as ram...shd will affect read/write speed..
chari-men
Theoretically it won't use our rom unless required or necessary loh.. I also turned off the online virus scanning, regularly update config data toggle in system manager.. bunch of redundant crap that eats battery life and cause bugs.. now the phone feels much snappier and faster love it ..
yhw22
NOOO...after 3 trial....will starting charging per image processing is 89 cents!
how come msia set can have 10 trials per day? we only 3 trials then need pay le? :(
Wah sian. I thought it was free to use. Not sure how about Honor 400, is their also 3 trials too?!
yhw22
V3 only got 12GB rom so far quite smooth. maybe v5 still not optimised yet. so far using M7P with 16GB was very smooth.
chari-men
Feel that this latest fw update was a rushed job for the triple split feature.. if I'm on 3 apps split.. pull out taskbar cannot swipe other apps for floating windows will crash..
yhw22
maybe, Singapore want to be in stores before Malaysia to be 1st outside the China to get it. Even Hong Kong will be available on 6th August onwards. Normally Hong Kong is the 1st outside China to get it.
Waiiii
mine is ok. can do like what you say 3 split screen apps with 4th floating is working.
chari-men
You can swipe up taskbar from bottom and launch floating windows from the app selection menu when in 3 split mode?? I can swipe from the sides for floating windows no issue but not from the taskbar..
