Honor Magic V5
chari-men
the drawer mode you all talking is it the bottom with arrow, dot and square icons? if so, it is nothing new, it is an android features. just search "drawer" @ settings.
I think he's referring to able to sort apps into folders in drawer mode..currently can only do it in home screen classic mode ..
yhw22
inside drawer mode....normally is full list of app....to sort into folder will be like....不三不四.....lol
Tuakong
I bought from Honor Shopee n after I had received the v5, pad 10 n pen, I msg them about the $40 voucher for the pwp of the keyboard.
They sent me voucher to claim via the shopee chat
The keyboard is preorder n ETA is Mid Aug
shager
Honor said that the feature is free of charge only for the first two months after activation. For those two months, an Honor 400 series phone user can attempt 10 Image to Video conversions per day.
https://www.hardwarezone.com.sg/mob...ro-review-phone-partially-ai-generated-review
I have the 400 Pro. Strictly 10 still image to video conversions per day, based on calendar day and resets after midnight.
If they are going to charge 89 cents per conversion after the 2 month trial, it's not worth it. Some are great but some of the converted videos are not so good as the face can suddenly change so that it looks like someone else.
doki81
yea..i help convert my ah ma and his sister photo..very old one...they make it live...but sudden...got 1 ang moh lady added into video..scary.
chenaz
Wah, compoetal portal(intune) doesn't work very well. Open teams or outlook need enter password everytime. Can't use finger print.
Magic 7 pro can use facial or finger print. Magic V5 can't even use finger print. Sibei turn off
chari-men
Found this on reddit for V3... Maybe you can try this
Settings -> Biometrics & Password -> scroll down to bottom where it says Work Profile - Click Fingerprints Add new fingerprints that are specific to your Work profile. Log out of your MS365/Work related apps and upon next login you should be able to use Biometrics to login instead of passwords. Check the settings of the Workapps in order to enable Biometric login.
chenaz
Wahh bro. You saved my life. Default setting is same as "lock screen" I untick "same login method" and register new finger as work profile.now my facial works again for normal login and now work profile apps can use finger print.u saved my life. Love u deep deep bro
chari-men
No problem.. I would have thought it should work the same as Magic 7 pro also lol...
