Honor Magic V5
maumu
sorry does anyone knows how to change the drawer layout to 5 rows instead of 4? In outer screen use
I've finally joined the foldable generation... :cool:
chari-men
Finally uh lol..can go settings , home screen style change to 5*6...
chari-men
I tried that, but it didn't work. still 4 rows instead of 5...
I'm looking at my settings now.. dual screen mode is toggled on as well.. can see 5x6 for outer and inner screen..are you updated to the latest firmware?? Maybe play around with the settings a bit .
maumu
not sure if we're referring to the same issue :o
I can get 5 x 6 on the outer screen, but when I pull up the drawer to see all the apps (I use 'drawer' instead of 'standard' under home screen style), the apps are sorted in 4 rows instead of 5 rows (or columns).
not sure if it's a bug or is it like this for all Honor phones?
Having 5 rows allow me to see more apps at once as I scroll down...
chari-men
My bad missed the drawer part...I think their drawer layout is buggy.. u can't launch an app from taskbar mode with that layout.. I switched back to classic..
hyperfuse
Went to m1 shop and compare fold 7 and v5 side by side with a 4k hdr video. Same video..same max brightness...same color temp at vibrant.
The fold 7 is more vibrant and brighter than the v5.
Puzzling. Thought honor v5 is 5000 nits and brighter?
Anyway..v5 had a better deal with my contract..so just buy it. 950sgd.
twosix
5000 nits may be a certain spot of the display only, not the whole display.
maumu
anyone knows how to terminate / stop some of the Honor system notifications?
the phone keep asking me every few hours to 'setup the phone' by restoring from some backup... but I setup the phone from scratch instead.
how to tell the phone that I do not want to restore from any backup? When I click 'skip' it'll still prompt me again after a few hours.
klcc121
is there a way without download 3rd party app to resize the photo to smaller size when attach them to gmail/ outlook?
hyperfuse
i am aware that the front screen and inside screen of the V5 comes with a screen protector by default.
Does the camera lens also fitted with a screen protector?
chari-men
Don't have..tho the front SP quite cui recommend to replace a better one..camera it's up to u.. maybe can get those with holes so that cam quality not affected..
hyperfuse
Coming from Samsung phones, I normally buy spigen cases which are affordable and good.
Cant find good brand honor v5 cases though. Got any to recommend?
chari-men
I don't use case can't be of much help lol.. the case that came with the phone is quite good tho.. integrated stand ..
maumu
on top of this, I'm also receiving system warning notifications about some apps draining the battery (e.g. whatsapp). is there a way to turn off such notifications?
quite annoying (although the intention is good).
