Honor Magic V5
phiber
Did anyone experience the screen turned yellowish like the eye care comfort is on after updating to the latest 9.0.1.159? Checked all settings and tried turning off all display settings.. still yellowish now!
Yeah.. my screen becomes night / sleep mode after 7pm.. check all the settings and they are not set.. sighed.. looks like a firmware bug.on mine!
phiber
try clear system cache yet?
Did that via boot menu, clear cache.. no use..
Maybe can consult SC see if it's hw issue??
Not hw issue.. before 7pm screen is fine.. after 7pm.. screen go into "night mode", yellowish to reduce blue light..
I checked all the possible blue light, sleep mode, night mode, comfort mode, display modes,,, all turned off..
Seems like OS bug..
doki81
Seems like OS bug..
eih, mine don't have this issue ...on latest ota also. my night mode did kick in follow my setting.
chari-men
Seems like OS bug..
Check your schedule settings... Maybe u got a routine app with night settings ..
yhw22
Not sure of V5, but M7P got battery capacity.
Under Settings - Battery - More battery setting - inside "Maximum capacity".
phiber
Checked all possible schedules and settings.. I did not set one before.. it started happened on the day I installed the beta update.. sigh..
doki81
what beta did you join? Magic OS 10?
yhw22
Tryout version.. 9.0.1.159.. lol
please dont be confused that tryout version is beta. beta version only for those who register it. no company will push anything not properly tested to user!!!!! only xxxx coy....lol if u know i'm referring to who had lot of saga after releasing it......lol
