Honor Magic V5
doki81
anybody bought the original magsafe back case without the hinge protection?
https://www.honor.com/uk/honor-choi...tbPvm27kwGiiT5m7tra78tti3WWLPsK_eUVTizvr1ybT8
better get fiber case with hinge protect....once u scratch a bit on your phone body..your warranty is voided!
Wei ming
Hi guys, are there differences in terms of features or OS, between global and CN rom specifically for HMV5?
doki81
china rom need self install google service..and using another AI call yoyo..also take note china set no esim.
keithlim
Honor has their own AI assistant called Yoyo. This is on the China version.
Global ROM version uses Google assistant (or Gemini).
A few more pros and cons:
Global version
+ has eSIM
+ local warranty
- only one config (512GB)
China version
- no eSIM
- no local warranty
+/- more local China apps which may be bloatware for some, but I know a colleague who love those China apps
+ more config. The 1TB version has a bigger battery (6100mah I think)
+ cheaper than Global version if you buy locally in China
? Not sure, but usually China local ROM has more aggressive power management and some notifications (Microsoft Team, Whatsapp) may get delayed response.
yhw22
Global version
+ has eSIM
+ local warranty
China version
- no eSIM
- no local warranty
by default, China rom don't come installed with GSM, GSM will be available once an overseas simcard inserted that allows you to self installation of GMS, Google Playstore, etc.......
Wei ming
Global version
+ has eSIM
+ local warranty
China version
- no eSIM
- no local warranty
Thanks for this. I'm looking if there's OS features that will only be China exclusive. E.g Yoyo assistant would be one
Sn0L@rx
hi there,
am i incorrect that the v5 is limited by software/hardware capabilities for NFC payment via facial recognition?
doki81
new parameter OTA arrived, 10kb++ only. said to improve system performance.. :vijayadmin:
after this OTA, seem like netflix no longer give error...for now.
on another note, Magic OS 10 official is now released in EU for magic 7 pro. can't wait!
yhw22
wah so fast ah.......
Apparatus
Guess Android 16 coming for my S24U just got the Android 16 update
:D
