Honor Magic V5
maumu
Why don't we write to Honor Official (China) itself to complain about the service quality of Honor Singapore? Will they do something like send their reps to SG to overhaul the service standards here?
It's quite appalling that a company like Honor would let its reputation be tarnished by poor aftersale support. Particularly in a country like Singapore.
doki81
no use de la...customer base not huge enough to make any impact.
kashix
Posting here as there's more traffic and users here. Anyone know how to get 5G-SA working on magic phones? Like V5 and M8 Pro? I don't see any toggle for 5G-SA like on iPhone.
nuscape
isn't that automatic for SA & non-SA?
how did u check if 5G-SA not working on V5?
SuperDecker
There isn't a way to select SA mode only. When I changed my zym sim card to 5g, I could not find a way to select SA only. In developer options, 5g mode only allows NSA or SA+NSA.
Another boo to magic os...
silverstone
similar to oneplus/oppo phone, just select SA+NSA in developer options, it will connect to SA if yr telco and/or Sim card is 5G SA compatible.
on the other hand, singtel mvnos like zym/zero 1/vivifi is not SA enabled yet.
nuscape
so by default without developer mode is only NSA?
silverstone
if yr telco/sim card is 5G SA compatible, i reckon u could it leave it on default, which is auto.
if SA compatible and u are not connecting to SA, then u could force it by selecting NSA+SA.
if u are using main singtel sim only plan, Eight 5G and/or m1 maxx 5G, u can try to leave it on default 1st and see how it goes.
phiber
Anyone got a good recommendation for front screen protector that can put case? Tried an X-it one that peels when I put the edge case for the front..
chenaz
Anyone knows if we can install mate protector on original screen? I saw taobao some seller said no need their one is thin enough to retain the original one.
neptunesea
SA is working for me on my V5 however the phone seems to be very aggressive on switching to NSA whenever I'm on the go. My guess is that it doesn't like interference variations on SA n78 and is configured to latch onto NSA b8 first before trying SA n1 or SA n28.
I have tried every trick in the book and could not disable NSA or go into the manual cellular band selection menu.
maumu
yup even in dev mode, can only select SA+NSA and not SA only.
by the way, for those of you on SingTel 5G, do you see VoLTE or VoNR? apparently, SingTel says there's no VoNR support for Honor Magic V5 sia. dunno what kinda logic is that, and claim that it's Honor's issue, not SingTel's (i.e. need Honor to release a software patch to support Singtel VoNR).
when I was using M1 5G and Starhub 5G, the phone shows VoNR.
neptunesea
Use pixel IMS to force enable VoNR. I have done it successfully, don't need to root. (am on singtel postpaid)
The default carrier profile resets everytime when you restart the device, so you'd have to reenable via pixel IMS.
doki81
anyone v5 having this weird issue like super fast charging suddenly become normal charging? was using original cable and the honor fast charger.
restart phone and the fast charging come back for a while before it get back to normal charging. in aircond environment and phone is not hot at all.
yhw22
you may want to replug in the cable, which I sometimes also encounter.
doki81
tested replug also same...unless i do a restart then it will go back 66w again. so annoying. turn off smart charging also same..
