Huawei and oppo
caterham7
Where to buy redmi 2 enhance at good price? Does it mean redmi2 is older phone than mi4?
Can buy from mi.com, $179
Should try before buying. Redmi 2 sets available at singtel shops or xiaomi service centre at clarke quay.
An older model doesn't really mean anything... i purchased an "older" model, htc butterfly 2 recently for $398, i personally find it to be ok, no issues relating to future-proofing; can be upgraded to android 5.0, etc.
when buying a phone, you need to do some research, check reviews, try out the phone physically...
neanea
caterham7 thanks for the info. I noticed mi4 hardware specs is so much better than mi2 why go for mi2?
caterham7
mi4i & redmi 2 belong to different price range, so specs will definitely be different
you mentioned budget of $250 earlier, so forumers will not mention mi4i, which is $279 [32gb version is $319]
you should go to the respective mi4i and redmi 2 threads to read up on feedback from actual users
fyi, suggest you use exact model name; mi4 is another model, so is mi2; when you use shortcut, people will get confused
should use mi4i & redmi 2 respectively... :)
neanea
I can stretch my budget $250 - $300 since I want to hold the phone for 2yrs. Does it make sense for mi4i or even some other brands that support dual sim?
JuXn5566
Imho, there wasn't any good phone between 250-300 range right now. The Mi4i got a serious problem, the phone heats up easily and become very slow. It's either you go with low end(below 200) or mid-high end(~$500), mid range is usually not worth it.
Sent from Xiaomi MI NOTE LTE using GAGT
neanea
My requirement is only a good camera and good battery and fast internet surfing speed. Which low end phones should I look at?
caterham7
Anyone knows where to buy ZTE blade s6 at good price?
have you try searching?
e.g. using the following keywords
zte blade s6 singapore
top search results include reviews & pricing info, including zte singapore facebook page, that also mentions that demo sets are available at m1 shops & gain city shops
Apex
Poor camera? Poor battery life? Or slow Internet browsing?
- Issue with Front Camera like CCD spoil like that
- Battery cmi. I only enable 1 SIM and found battery drain very fast
- Not sure if CPU or UI. Slagging performance even enable the "Performance mode"
ykgoh
WTF! :eek: Really is cui max!
8-lane
Or u can consider the Asus Padfone S for just a little over $200 bucks.. drastic drop in price..
