Huawei Mate 10
Dorkable
Hi, is the Mate 10 Pro selfie cam still having the crazy overexposed (white face) pics when beauty meter is turned on even just half way? Thanks :)
plsdunbiteme
My mate 10 pro has 1 light scratch when took out of the box. Went to redwhitemobile and was being directed to huawei. Scratch is only viewable at certain angle and under strong light
Should i go change?
Scratch on the screen or on phone body? From my experience, minor cosmetic defects are unavoidable one when buying new phone. As long as not too glaring, and does not affect the phone function, better to live with it than go through a lot of trouble to exchange it.
falcoroy
No. The Huawei themes app is working for local set. Probably some issues with your firmware..
FYI, its working for my Mate 10. It should work for your Pro set. Are you signed in to Huawei ID? Tried resetting the phone?
Yes, Huawei ID logged in. I aleady tried to reset myself and @ the service centre too. Still the problem persists...*facepalm
KeYoKe
Scratch on body haha. Doesnt really affect so thats why still considering whether to go huawei
barnabaskoh
charger and cable.
HIHI, i read about all the awesome of using the HW super charging, may i know how long does it take using its super charging to charge from zero to full? if i do not have the original cable or charger and uses those anker quick charge 3.0 charger and cable will it be as fast or slower? If it is slower, how long does it take for non orignial charger and cable to charge to full from zero? thinking of buying tomorrow so needs to find out more
eden1988
Anyone knows what does the below do?
LTE high-speed mode
Cat16/Cat18 requires mobile data.
Anyone tried enabling it before and does it work in Singapore??
barnabaskoh
i also read that HW phone stays fast even after weeks or months of using which is different from typical android phone that lags after a few months, is that true?
maumu
I've never charged from zero to full but can say it's really super fast... you can easily get 50% or more with less than 30 minutes of charging.
u need to use Huawei's proprietary charger and charging cable which supports super charge. quick charge (2.1A) is not as fast as super charge (5A). I think there are some rare alternatives out there which mimics the super charge of Huawei, can google.
so far after using 2 mths, can't really see that it lags. it regularly shows how much ram is free (out of 6GB) so u can monitor. I don't see how the NPU (AI) actually works though...
actually having use android for years I've never really notice significant slowness/lag in my phones (all previous were Sony), except maybe the Samsung tab 2 (tablet). the lag is killing me for that one.
knave
For me I experienced Samsung lagging after a few months of usage.
The key difference is that the Mate 10 / Emui 8 will auto prompt periodically, for you to defrag the device. So seems that helps?
barnabaskoh
I see, thanks for the replies. I have been a note user till 4, didn't get 7 as it exploded and since than have been trying to find a replacement and this seems like it. Only thing wasted is it does not have a pen.. But I seldom use it anyway.. Hopefully the price don't keep going up every year..
maumu
android phones have been known to drop value quite quickly... I think it's much cheaper now compared to launch.
but you're right... flagship phones have been costing more and more each year :(
barnabaskoh
Hi I am buying a set of charger with cable at $27 dollar later. Anyway to check if the charger is original?
louislaw
using mate 10 pro and its a really good. battery life is superb, and the camera's low light performance is a big upgrade over mate 9. but i do feel that the screen is a little bit too small (at least for me), does anybody feel the same?
hope to see mate 11 comes with 6.2 or 6.3 inches 18:9 ratio so that it will has the same width as the mate 9.
louislaw
Ya does the local Huawei mate 10 pro comes with earpiece since it does not have audio jack?
it comes with a type-c earpiece, which u can directly plug it in into your phone. there is also a type-c to audio jack adapter just in case you want to use your own earpiece.
tbh this is the part i like huawei the most: remove the audio jack, but give u a type-c earpiece. so far i think they are the only one who doing this.
barnabaskoh
Yes! I bought one for myself and one for my daughter. Can't wait to open it later! It's better to buy a hub that can connects to hdmi and mouse and keyboard right?
