Huawei Mate 10
haylui
Btw for those who tried using the Monochrome mode, is it hard to get a good picture?
Like it's easier to be blur, compared to normal coloured. Taking the same photo, color then monochrome, a lot of times color sharper.
And I feel like the sharpness and detail is much lower than colored, like if you zoom in texts, can see the monochrome not as sharp.
Colour sensor has more pixel and monochrome has less pixel. This is what interpret from the Huawei mate 10 Pro spec.
SuperDecker
Just checked my warranty online and with Huawei, the screen crack warranty is only 3 months from purchase date. It was one year with mate 9. Shouldn't it be one year as standard with other makes like Samsung etc?
eyz
no bro. mate 10 is 3 months only.
my wife's mate 9 is 1 year.
haylui
I know. That's why I said what "I can do with the phone". :D
Anyway, I'm still exploring it's features. But I'm already impressed with the overall smoothness and speed. :s12:
At least it won't makes you feel like a sub par phone. By the brand, maybe people thinks another China phone. But the performance is very solid.
progene
Hopefully Huawei will not forget us and update our mate10/10 pro to 8.1 with all the P20 features...
Sent from HUAWEI ALP-L29 using GAGT
tekster
One feature which i appreciate greatly is the ability to block apps from eating yr mobile data.
Eg i don't want gmail to sync while I'm out of home. So now it only syncs when i have free wifi or at home.
Shib
Sorry, can share what is this feature?
Perdedor
Is nilkin the best fit tempered glass for mate10pro? It seems it doesn't fit the curve edges.. anyone has good lobang on one that fits the full screen & allows for a fit into a Spigen case?
SuperDecker
I order this tempered glass also and pending another 2 from taobao. Will try it out and let u know. Tempered glass is always a hit and miss affair. Bought quite a few from taobao to test
SuperDecker
Facebook is running amok on my battery life, drained alot overnight. Stopped notification and off automatic launch (switched to manual and off all the options) but doesn't seem to work. Any other ways?
Shib
Turn on power saving or go ultra battery? They helped to reduce those background sync.
eden1988
Remember insert your Malaysia SIM card.btw this trick doesn't work for me.
Actually don't need to use a msian sim card, just need to activate msia telco on a local sim while traveling to msia and it will work.
I got my v.131 update this way, after my biz trip to msia using a StarHub/Singtel local sim card.
wisely2000
Got this issue.. Why whenever i off the phone.. Then after a while restart it.. The pics that people used to whatsapp me cannot be open.. Or download.. Have to go to storage cleaner to clean unuse apps or files.... Then can use
