- Jul 14, 2005
B135 firmware is out at huawei firmware finder... Time to update tonight
Ya lor m10p. Mine shows till 135. Just approved today. I have been checking daily lolM10P?
I see Europe have 137 already for M10P.
My M10 is still on 131, with 132 in FF but not able approved.
Those of you using mate 10 pro, any idea how to disable the auto popup for sms and WhatsApp?
Why are you so sure it's Huawei fw issue? Asus router has no issue. Can I blame it on Singtel shitty router?
I have both SingTel and Asus router. SingTel router need to be restarted like once a month or more.
Sometimes need to call 1688 to reset at their end to resolve the problems...
I'm not sure about Xiaomi's MiUi, but I don't noticed the WiFi dropping off on my Mate 10 Pro. I'm using M1.
Because it also happen when using wireless.sgx hot spot.
Hmm... I checked FF, with IMEI is "not approved". Without IMEI is "approved". Don't know can install or not.Ya lor m10p. Mine shows till 135. Just approved today. I have been checking daily lol
My TV is not smart TV. Just a normal LED TV.Singtel use van method. Not suprise to hear that. If you also have Samsung TV (model from/after year 2016). You may also want to check router logs as Samsung TV broadcast himself as local host which conflict with some router firmware. If the error rate is high. Your router will finally hung and need to reboot.
Hopefully whatever changes they made to P20 can port to our phones. Haha
I'm pretty sure its not a hardware problem as well as I had 2 sets of M10P replaced and same problem. I'm no software expert so I can't really comment on this but so far I'm seeing this issue with my Singtel Arcadyan router. The Asus router I have in my hostel is not giving me any problems. Looks I'm not going home LOL.
Just keeping my fingers crossed that a firmware update can solve the issue. If not then change to a P20? Who knows![]()
Actually could it be the router setting that is causing this issue?I'm pretty sure its not a hardware problem as well as I had 2 sets of M10P replaced and same problem. I'm no software expert so I can't really comment on this but so far I'm seeing this issue with my Singtel Arcadyan router. The Asus router I have in my hostel is not giving me any problems. Looks I'm not going home LOL.
Just keeping my fingers crossed that a firmware update can solve the issue. If not then change to a P20? Who knows �
I am using starhub issued router, D-Link. Previously I had similar problem that when I play games or stream using my phone, the connection will dropped intermittently.
After googling a bit, someone on internet suggested that D-Link router has a setting that has to do with QoS and it's on by default.
After turning it off, my phone connection was never dropped anymore.
Not sure if it's the same issue with singtel router.
I have no prob with my netgear and Asus routers at home. Wireless sg also no problem. Only problem is the Bluetooth issue still present
I normally get logged on to this WIFI when I accidentally leave the WIFI on. Otherwise I prefer not to log onto it.I used dlink, so far never encountered such.I have no prob with my netgear and Asus routers at home. Wireless sg also no problem. Only problem is the Bluetooth issue still present
