Huawei Mate 10
potatoinapot
u forgot waterproof/water resistant? only pro model is...
EDITED: saw ur ip rating. oops. lol
Anyone knows the DAC is for all 3 models? i recall the official launch mentioned the DAC is better sounding. Seems to be pro model and above?
The launch very confusing. They go 10 pro 10 pro until I also don't know which feature only pro which is normal
Still no Telco info. Want change phone liao la.
eastcyber
Anyone knows if the NFC on the Mate 10 (not Pro) can be used for our bus and MRT travel?
Ezlink NFC website list of supported phones is last updated on end August. Been looking over the net but can't find any relevant information.....
doki81
Which Qoo10 vendor is recommended?
as long as they are local seller...then you are covered by the warranty...now it's come to what free gift they throw in...
for example:
Huawei Authorised Seller at Marina Square
they are throwing so many free gift which i think certainly exceed the $25 of qpoints..
compare to this another seller..which i think they first time appear in qoo10 but should be legit for local warranty..
Mosi Mosi
both allow self collection which you can save on delivery fee...but collection only start tomorrow..
sunht
http://www.ezlinknfc.com/supported-phones/
Should be, saw they have mate 9 supported.
Sent from NEXUS 6P using GAGT
kimwee
for example:
Mosi Mosi
The freebies seem pretty useless and cheap stuff to me lei. I'd rather get the $25 qoo points and buy something that I really need...
iamnagel
for example:
Mosi Mosi
I'm only wary of those that buy from users then repackage to sell as brand new
doki81
haha...if iphone then i am worry... Huawei phone.... re-sell value not high...dont think will have such issue..
you can choose to self collect and check on the spot.. :s13:
hongge
Bruce mobile from qoo10 is 889 less 100 less 25 shop discount = 764.
Use gift card 700 less 3% = save 21
764 less 21 = 743
Use singpost credit card 7% online cashback = save 52
Total mate10 cost = 743 less 52 = 691.
If u have 1000 qpoints, can offset another 10.
symbiote28
764 less 21 = 743
did the qpoints system change? i can only offset 500 points each time :s11:
avsquare
Yes, it works
Mate 10 (not Pro)
I don't think you need to be too worried about NFC for bus/MRT in general.
Before the Blackberry KeyOne is officially launched in SG, I have used an export set KeyOne and also owned an export set Priv and the NFC just works fine.
NFC is pretty much a standardized frame work so as long as it is NFC enabled phone it should work.
avsquare
Just bought my mate 10 mocha. Any bros have any idea if I can get any freebies from huawei service centre? Cos I'm not too sure myself if I'm entitled to any...
You are only entitled to the freebies if you have the redemption voucher given to you.
AFAIK those are for the pre-orders only
Although I have too despite I did not pre-order from Lazada. Got it from one of the Huawei's authorized shops.
kimwee
764 less 21 = 743
Got the link? Dunno y can't find on qoo10...
