Huawei Mate 20
blurboiboi
My mate 20 pro comes with a soft casing but I do not feel secured at all. Anyone found any lobang for a good mate 20 pro transparent casing? I like the colour so I definitely will not want a casing that covers the colour but i still want the protection :D
Share your loot please! I went to a mobile shop to install TG as well but he says will have bubbles as not fit entirely so i did not do it.. :(
No screen protector at this point??
garychengjw
Not sure if it ram issue. Coming from Mix2S and usually opened 4-5 app with MapleStory being locked from clearing.
On M20P, maple will need reload even locked and running at background. While my mix2s don't need.
Sent from Huawei Mate 20 Pro Emerald Green using GAGT
kuma-mon
Have u tried the camera app? Is the night mode good?
MisterU's
+1 here, have the same concern. Scouting for a rugged transparent case + TG or alternative screen protector.
Sent from HUAWEI LYA-L29 using GAGT
jlekssp
Do I have to enable fast charging or something? How come at 50% when I charge it using the original charger and cable, it still show 2hrs to complete charging? Anyone has this issue?
caesium2108
Saw on facebook this company Urban.M selling tempered glass protector for m20 & m20pro. Nt sure if its better quality compared to the ones at challenger? Any bros tried out yet?
jackycar
Changed to screen protector instead of tempered glass. $22 at Xgear at waterway point. Fingerprint scanner works perfect now.
Temporary solution until Whitedome or full adhesive tempered comes along
The scanner is really fast
Also, ibanking login with fingerprint works!
athenodorus
Turn on power saving mode, smart resolution and don't press your phone so much just because u got a new toy 😂
If need to do all these might as well use Nokia 3310.
If the phone drains unusually it could be the apps installed and background syncing. Monitor what apps causes the drain could help.
bellick
It's a curved display so you're better off waiting for Whitestone dome.. otherwise you might end up wasting more money on all the junk screen protectors.
Also, tech21 has cases for mate 20 pro. Maybe check with casefactorie when they have stock
MisterU's
Thanks for the advise �
Sent from HUAWEI Mate 20 Pro using GAGT
Abyssal.Xuan
Bro you try toggling the settings in app launch. Might be that function clearing minimised apps.
Go to 'settings'>'battery'>'app launch' then search for Maple then toggle. If it's on automatic then the AI might ending the process.
If you've already done it then.. I hope you get an appropriate answer soon! :)
ayuluv
Read that M1 has all freebies @ paragon & bugis yesterday.
Not sure how are the status for Singtel in terms of freebies
kyleongwl
I had tried.
Shootib across my flat (tree, bus top and walkway)
Night mode - dark sky turns more blue tress are much define
Std mode - dark sky remain dark...details of plant flat iu
Shooting a plant with red and green leaves
AI mode - light color
Std (with AI) - vibrant color
kyleongwl
Use the one from challenger...and bought the mate 20 silicon case...
TG size kinda out...fingerprint hit/miss
Silcon cover is smooth (but civer the beautiful green)
Abyssal.Xuan
On my second charge.
Started at 100% at 0756hrs. currently at 75% as of 1412hrs. Battery usage shows 2hrs of SOT. MY screen is at 1440p (WQHD+). AoD is on.
Usage for this charge includes:
Instagram
Reading wuxia webnovels on Chrome
Plugging in and listening to music for 30mins
Brawl stars here and there
WhatsApp
Telegram
Surfing this thread on PCWX app(lol)
Things I haven't done (cos I was out):
Chiong YT videos
Pubg (For pubg, the game hasn't been updated for the Mate 20 phones, go check recombinant videos. It's highlighted there! Gotta wait for a bit till the game includes better settings for us)
Netflix
Also, noticed that AoD doesn't have notifications. (Either I suaku or it doesn't support) to me that's fine.
Loving the phone so far!
