Huawei Mate 20
garychengjw
Bro you try toggling the settings in app launch. Might be that function clearing minimised apps.
Go to 'settings'>'battery'>'app launch' then search for Maple then toggle. If it's on automatic then the AI might ending the process.
If you've already done it then.. I hope you get an appropriate answer soon! :)
I went into app setting and toggle off it. Seems working a little better.
Sent from Huawei Mate 20 Pro Emerald Green using GAGT
siaoz85
Just pasted the film protector at waterpoint X Gear as well. Very clear and very well pasted. Slightly smaller than the free transparent case. No issues with fingerprint reader. Good temporary solution until Whitestone dome arrives.
savior1
Hi guys. Any recommendations for tempered glass or for those films that claim to be harder than glass for mate 20 pro?
Skyy
is the film smooth and oleophobic or is the rubbery TPU type?
tauintown
Anyone having problem with the free memory card reader and nano memory card? My computer cant seem to detect the F drive for the nano memory card from the memory card reader.
garychengjw
It detects when insert the phone while connect to PC.
It doesn't detects while in the USB stick via PC. Not sure need what kinds of drivers.
Sent from LG V30+ thinQ ~ Raspberry Rose~ using GAGT
icecapt
https://www.gsmarena.com/huawei_mate_20_pro-review-1845p7.php
Similar camera performance between P20 Pro and Mate 20 Pro. I guess P20P is still worth considering for those who don't need the extra features on M20P (wireless charging, reverse charging, etc.) especially now the price has dropped. :)
Probably going for P20 Pro, can't justify paying extra $550 for the Mate 20 Pro. The only real improvement to me is the wide-angle lens (coming from a LG V20 user) but that's about it. The other features are gimmicky/useless to me.
Skyy
i just read GSMArena's review.. the battery life is worser than the M10P by almost 13%, which is surprising considering how much HW waxed lyrical about the improved battery efficiency of the new Kirin 980. No wonder they had to up the battery to 4200mAh, else it'll be even worse.
ckling
Is it the high res screen draw a lot more power?
yoshiki84
Seems like most people bought the M20 pro. Anione who bought the normal M20 care to share some photos taken with M20 camera, especially with the night mode? Will be good to see how much difference there really is.
tohchr
I think I’m keeping my p20 pro. Missing the fast fingerprint scanning, screen is not curve edge and easier to find protector also. Unless it’s mate x, then will consider.
