Thanks alot do let me know ya
The CSO online says its a charger only...
So pathetic
Is anyone using Samsung Health with the 20 Pro? It doesn't seem to be recording steps when I'm walking with the phone in my pocket.
It detects when insert the phone while connect to PC.
It doesn't detects while in the USB stick via PC. Not sure need what kinds of drivers.
Sent from LG V30+ thinQ ~ Raspberry Rose~ using GAGT
Oh well, my recontract voucher ends on 31oct. Was thinking to wait for The Tech Show convention at suntec. Singtel doesn't allow to extent the voucher and might as well recontract online + $30 off online purchase
Is it the high res screen draw a lot more power?
i just read GSMArena's review.. the battery life is worser than the M10P by almost 13%, which is surprising considering how much HW waxed lyrical about the improved battery efficiency of the new Kirin 980. No wonder they had to up the battery to 4200mAh, else it'll be even worse.
I think I’m keeping my p20 pro. Missing the fast fingerprint scanning, screen is not curve edge and easier to find protector also. Unless it’s mate x, then will consider.
Anyone knows where can I still get my hands on this phone? CWP got ready stocks for the phone?
Another plus point for Huawei is 2 Yr warranty.. Recently screen cracks send in, no need receipt and best part its free.
Thanks for the recommendation, just had mine done there and it's a night and day difference compared to the TG from Challenger.Changed to screen protector instead of tempered glass. $22 at Xgear at waterway point. Fingerprint scanner works perfect now.
Temporary solution until Whitedome or full adhesive tempered comes along
The scanner is really fast
Also, ibanking login with fingerprint works!
I ordered from Thailand and the authorised set even cheaper than sg. Mate 20 x. Pro series also cheaper. Singapore really everything more expensive now.no word on local release. your best bet for now is JB set from 11 november onwards.
Did you all enable Master AI setting in the camera app?
Any difference if it's enabled or disabled?
Posted from PCWX using SONY SUMIRE
If you don't need that raw power, added features, P20P is still a great phone but M20P is just a different league when it comes to speed. Android phones has never been able to beat iPhones when it comes to speed test on launching app/games but M20P has just turned the table around..
Anyone knows if there is going to be a 40W Huawei Supercharger for car?
