Huawei Mate 20
coolant
Suspended
Of course mate 20 pro, wide angle lens vs monochrome len of p20, 7nm processor vs 10nm one of p20. Ud fingerprint, bigger battery capacity, newer android version, the list goes on
athenodorus
full adhesive loca glue tempered glass. works fine with in screen fp scanner. able to fit the default case.
30 bucks @ red white.
athenodorus
Guys!!
Anyone knows how to show contents of notification on the locked screen?I tried looking at the notification page under lock screen notifications but still not able to tho��
this is huawei issue. their aod doesn't support 3rd party notifications. sucks right i know:(
Skyy
Intending to upgrade my phone from Mi Max.
Between P20 Pro and Mate 20, may i know which one is more recommended since they are priced in the same range.
Mate 20 for sure. Other than the oled screen of the p20p, there's no real advantage over the m20
jackycar
He asked mate 20 not mate 20 pro
amazingone
P20 Pro have the powerful 40MP camera lens, which is the same on the Mate 20 Pro.
However, the Mate 20 has the wide angle lens, which the P20 Pro doesn't have.
limcc
If you referring to mate 20 vs p20 pro.
The mate 20 has better SoC = better performance; bigger LCD screen; ultra wide angle camera; 3.5mm headphone jack; expandable storage using NM; etc
The P20 Pro has better camera 40Mp/10Mp/Monochrome; front fingerprint offer single button gesture; IP67 dust/water resistant; smaller size; street price cheaper by ~$100; etc
symbiote28
Yes!! It is! Same cable same plug.
thanks man! wow, this makes the whole wireless charger as a freebie even sweeter!
so next question is, will the 15W wireless charger be at full capacity only when we use the 40W power adapter? i read somewhere that you need to use only that to achieve such speed for wireless charging.
