Huawei Mate 20
kirium76
full adhesive loca glue tempered glass. works fine with in screen fp scanner. able to fit the default case.
30 bucks @ red white.
Do you have to press Harder than usual for the fingerprint scanner as compared to naked?
Cute chicky btw. :)
Sent from Samsung SM-N950F using GAGT
tohchr
Intending to upgrade my phone from Mi Max.
Between P20 Pro and Mate 20, may i know which one is more recommended since they are priced in the same range.
If only between p20 pro and mate 20 non pro, my preference will be towards p20pro. Personal preferences.
Abyssal.Xuan
thanks man! wow, this makes the whole wireless charger as a freebie even sweeter!
so next question is, will the 15W wireless charger be at full capacity only when we use the 40W power adapter? i read somewhere that you need to use only that to achieve such speed for wireless charging.
Ok bro, I can't answer that. HAHAH. I haven't tried either. But I would assume you'd need a good enough adapter to draw enough Watts to be able to power the wireless charger to 15w.
Anyone can correct me if I'm wrong man :s13:
kaon
Sorry, if this has appeared somewhere before, but what is the best deal for Mate 20 / Mate 20 Pro so far?
What was the deal at Causeway Point?
Am I correct that SG only has these 2 variants:
- Mate 20 128GB
- Mate 20 Pro 128GB
haylui
If you referring to mate 20 vs p20 pro.
The mate 20 has better SoC = better performance; bigger LCD screen; ultra wide angle camera; 3.5mm headphone jack; expandable storage using NM; etc
The P20 Pro has better camera 40Mp/10Mp/Monochrome; front fingerprint offer single button gesture; IP67 dust/water resistant; smaller size; street price cheaper by ~$100; etc
Loudspeaker p20 pro is better than mate 20.
kaya14
Also looking to do a recon to mate 20 or P20 pro. Now it's down to wide angle cam VS 3.5 mm jack... :(
Sent from Xiaomi REDMI 4X using GAGT
haylui
Better get mate 20 than p20 pro since it has wide angle lens, more useful than monochrome cam.
stardark
dont really know how to explain. u try calling on loudspeaker, then u observe the top left side.
prayerboy
Personally I prefer the P20 Pro. The lenses specs of the P20 Pro is much better, and the monochrome cam helps to get more details, esp in low light.
As much as I like the wide angle lens, I think it’s good only in the M20 Pro. But comparing the price diff, esp for the telco plan prices where the price diff between M20 Pro and P20 Pro is more than $450, I’m going for the P20 Pro. I would have gone for the M20 Pro if the price diff was more like $250 instead.
techizen2
Try swap the slots for the 2 SIMs...could be a pri or sec slot thing...
Already did that. Same problem. It's like the phone is always giving the Singtel SIM higher priority.
The weird thing is that when I disable the Singtel SIM, the Digi SIM still cannot work. I have to remove the Singtel SIM from the phone before the Digi SIM starts to function properly again.
athenodorus
Hmm somehow I don't see hwz ads using chrome. Is it due to the huawei VPN? If it is it's so cool to not have to install adblocker sia.
tenshinoir
Did u turn off the call forwarding sim option? And set the default sim and default sim calling when you travel back to msia
xuan123
Just a curious question....
do yall tend to use your phone while charging?? or just let it charge finish then use?
