Huawei Mate 20
jackycar
There's bumper for it? Can take photo?
Sent from HUAWEI Mate 20 Pro Emerald Green using GAGT
Abyssal.Xuan
Bleeding at the edge? Is it defective? Meaning there are gaps. Will it affect the IP property? Can take a Pic to show us the bleeding?
Sent from Samsung SM-N950F using GAGT
Just realised I have this too. Thinking if I should call hw tomorrow to check ):
Pictures taken from Reddit post here:
https://www.reddit.com/r/Huawei/comm...ve_a_glue_gate
exact same yellowness for my phone. More obvious when when using phone in the dark with brightness at 0.
The bottom pic, get a black picture, then turn your brightness to maximum. I got similar results. yellow blobs ):
I'm sad that this is true but I guess there'll always be bad batches. Hopefully hw can help!
rampage_111
Yep.. 1st pic is what I'm referring to.. Anyone else experience this?
Kitschme
Hi folks. Will the Huawei Mata 20 Pro UD variant from China (8gb ram + 256gb rom - me kiasu, want bigger specs) work in Singapore? (i.e. Cellular signal, 4G, google playstore, payment apps, updates)? I have a friend in China who can help me get the phone and ship to Sg. If it does work, keen to get that variant, which is only available in China.
Yup I got my mate 20 x from China and it can download playstore etc. Just a bit troublesome having to deal with the additional Huawei apps and installing Google apps.
Sent from HUAWEI LYA-L29 using GAGT
techizen2
Have you solve your problem? It could be a bug, or just few of us.
this is my 2nd set of mate 20pro and it still have the same problem. My SIM 1 will become "No Service" after a while. I have both Starhub Sim, one postpaid and 1 prepaid and i don't understand why my postpaid is always having problem. When i swop my postpaid sim to Sim 2. it works perfectly. But when i switch it back to Sim 1 for postpaid sim, it will become deactivate after a while...any one has this issue? I did a one to one and same thing happen so i suspect it is a bug. Those who use two SIMs, any issue?
:s22:
After factory reset, both my SIM cards functioning now. Singtel Postpaid as SIM1 and Digi Prepaid as SIM2. I stayed away from Phone Clone this time.
In total darkness, my phone have totally no bleeding light.
My only problem now is all my Notification Badge is just a green dot. Can't find a way to make it a numbered red dot.
Beta_Tester
How do i use a second sim card? I am going overseas. I want to off the data roam for the Singtel one but use the overseas sim card. Other than the plug n play part.
Never use a dual sim in my life before. Are there settings to on and off.
Thanks.
jlekssp
I have done that in the first one before i exchange with them. Reset phone right?
Have you tried making a few calls? Switch your default mobile data again, and then maybe after that, make a few calls and see if it stays ok. Imagine you go oversea and you will make this move.
Anyone else has this problem?
techizen2
Have not done all that yet. My main passed criteria was the *100# check. It works now for Digi so I assume all is well. Need to find time go to Malaysia to perform more test, especially using Digi data
techizen2
Thanks.
I always make sure that the Singtel data roam is switched off because it is super expensive if you did not purchase a data roam pack.
Just select the mobile data to the other card. Quite straight forward, based on my LG V20 experience. Haven't fully test this yet in Malaysia with my M20Pro.
jlekssp
sorry what is this check for?
petricnah
Just an up date, the Mate 20 pro FOC case not suitable to go with the $30 TP from Red White mobile.
This morning found 3 corners with air gaps
kirium76
Any fp sensivity issue with this full adhesive tempered glass?
James Tang
Does our mate 20 pro have a a camera lens protector? If none, have you guys installed one?
Sent from HUAWEI Mate 20 Pro using GAGT
This may alter the light passing through.... usually people don't stick anything there. But if you really want, can try to buy those good protective film and cut
kirium76
I saw in carousel that another seller in marina sq is offering full adhesive too. But ex at 49.90.:(
athenodorus
I already showed that mine works well with the case. U put on the case immediately after installation? Likely the application isn’t fully cured yet.
kirium76
You still encounter inconsistent fp scanning performance?
