Huawei Mate 20
spunkbrat
They probably have the entire CN fingerprints, so no need. Worldwide issue to collect all our fingerprints. :s22:
Got 3D scan of face, fingerprints and probably personal information on the phone, so easy to forge documents and identity.
p0mp0m
For the fingerprint unlock, can it be done without the screen turn on?
Or I have to either tap the power button at the side, or keep it in constant idle mode.
MrLampa
I put the spigen casing. Now a lot of shop cant put for me screen protector sian because of the spigen casing
mosprockett
Just got my m20pro.... Super impressed.
Nice size, great camera, zero lagginess so far, crazy battery life.... This might be the best android I've used so far
Posted from PCWX using LYA-L29
St00ky
been reading this thread. seems like there are more Pro users here compared to the regular Mate 20? could not decide whether to get Pro or non pro
mosprockett
If money is an issue go for m20... Otherwise m20p no regrets bro... For something with hours of daily use, I feel. Is worth it to spend la. I don't think there's many thungs that we can say that we use for hours a day.
Retrospect18
Anyone having issues with apps push notifications not coming through? My Skype app notifications are not showing and there's no badges as well.. Ok for whatsapp and fb.. Just my Skype..
algerr
Singtel and huawei not in tech show :x
Hmm..the map shows singtel at lv4
Sent from Nokia 8250 using GAGT
amazingone
If you want better camera, the Mate20 Pro will be the choice. It's sort of an all-rounder flagship, with features such as wireless charging, IP68 rating etc.
The Mate20 is not say a bad choice too, which you still can consider as it still has the wide-angle camera albeit at a lower MP count.
knave
Check under Ignore Optimisation and battery > launch.
Emui is aggressive in killing background apps to save battery. You need to specifically whitelist those apps you want to have real-time connection, like msging apps, email apps etc.
Once whitelisted, it works fine.
knave
Ordered a non pro myself (delivery tmr). As much as I want that camera and AMOLED screen, couldn't convince myself to use a smaller screen phone + uncomfortable curves and yet pay that much more.
andy77
How to activate the macro when taking photo? I tried at telecom only sometimes work, fully control by AI?
1982-1994
M20 is very compact due to the screen to body ratio, so far it has the highest rating currently at 88%. Find X has 87%.
