Huawei Mate 20
kryptonit3
Yes, I have 1st hand experience on this. I went P2O Mobile to get the UAG case for M20Pro, there is some clearance at the top and bottom of the phone which does not exert pressure on the full adhesive tempered glass from Red White. I am waiting for a smaller UV full adhesive tempered glass from P2O or Red White then the M20Pro should be issue free for me.
No proper tempered glass to fit aftermarket cases is a pain in the A***. I'm still holding on to my Xs Max, if no solution for the tempered glass, gonna switch back to the Xs Max and sell the M20Pro.
I really hope that phone makers do not make all these fancy curved displays, no usefulness and give us users alot of hassle when installing tempered glass protectors and cases.
just wait for whitestone.. down side of loca glue installation is if dust is trap on the edges if didn't wipe careful will cause some of the glue to come off.. will see a white peel off area at the side, those with OCD don't keep wiping the edges will do.
Skyy
U mean for Whitestone, the glue so strong that it won't get pushed up by cases? Or is Whitestone smaller that's why it's case friendly?
Geros_Peters
Yeah well said. I agreed. Thanks to Samsung.
Thanks, High 5!
Bro UAG case come out already?
Yes, got it today from P2O Mobile $39. Only 1 Color available, Smoke Black Translucent Plasma Series.
I had some leftover whitestone glue and used it on the non white stone tempered glass. The Spigen case is too snug fitting. One corner got pushed up. Now UAG case top and bottom has approx. 1mm clearance from the tempered glass BUT the sides seem to be quite snug fitting. I am keeping the tempered glass on still to monitor for further pop ups with the UAG case and at the same time waiting for new revised design of a smaller version of the tempered glass.
My job is outdoor sales, I move around alot and my phone I keep inside my rear right pocket and only when sitting down then I take out. Confirm easy to get scratches. I also sell my phones in rather short time so I want to keep my phones in good condition to sell for the best value.
Cannot stand seeing scratches or dents on my phone. OCD :s13:
Geros_Peters
White Stone have not come out with tempered glass protector for the M20Pro yet. Whitestone should be a korean brand if I remember correctly. Might not release a tempered glass for huawei which is a china brand.
D*** curved screen phones! :s13:
jackycar
Bro, just use protective film for the time being. Using it for over a week already no scratches etc also.
kryptonit3
their edge round curve area is smaller so edges space to side of case have wider gap.. used it during S8 era.
p20, p20 pro have it... so worth a wait I guess?
Geros_Peters
Where did you get the protective film?
I did not know whitestone made it for the P20 and P20 Pro. Its worth a wait for sure
DeMisE
Mind if you take pictures of the UAG case with the phone in it?
I've been looking for a rugged case that is transparent, not sure how this UAG case will look with the twilight back of the Mate 20 Pro.
The Spigen case cover the back, but I too clumsy, very scared drop the phone with the free case that doesn't protect much of the phone.
lorettatay
Mate 20 Pro UV Liquid Tempered Glass for S$32 https://sg.carousell.com/p/197936332
Intend to get from him to try
Sent from Google PIXEL 3 XL using GAGT
Geros_Peters
Sure no problem, just nice mine also twilight.
kyleongwl
No matching glass and case... Will sell off?
If u are used to curve screen, it normal (seen in Sammy phone)
Geros_Peters
Thanks bro, you feel that the case hides alot of the twilight or you okay with it?
Welcome. I do feel due to the case being smoked black, it hides alot of the twilight back but I'm ok with it. Subtle look is pretty good to me. I was using the spigen armour case previously, totally can't see any of the twilight back at all.
i_dun_understand
just order healing protective film from Taobao. It come out with a installation kit to resolve the alignment problem.
Also order the protective glass for the camera.
Total cost is less around SGD 10++
Geros_Peters
Right now just waiting for the right tempered glass protector. If still no good tempered glass will swap back to the Xs Max. I had switched from the Xs Max to the M20Pro. I have not used Samsung phones since the S8 Plus when it was first launched. Used it for a week then sold it off due to the lack of proper tempered glass protectors back then. Only perimeter adhesive type back then.
Geros_Peters
I have the same case too. Got it at Mobile Hardware at $31 hehe. But their full adhesive have black borders and don't cover fully.
Does the one you applied at red white mobile have black border? Does it cover full screen?
Your price is good! I got mine at $39.......the one at red white is totally clear, no black border and covers full screen. The spigen case was too snug fitting and pushed up the protector.
