Huawei Mate 20
jackycar
Battery life much better after switching back to Emui default launcher from nova launcher. 19h usage according to Battery stats and 13% left (SOT was 7hrs+)
Another bro here said nova launcher batt life v good, could it be because I restored my icon layout?
Tuakong
I didn't do any comparison but I switched to stock after reading that nova launcher comsumes more batt
Happy with stock so far
I m a hw fan now
No more LG, Samsung or even iPhones for me
softlink
Any way to disable hisearch from emui default launcher? It is annoying unable to pull down notification from middle of screen.
superio
Hi bro, anyone knows if it's possible to get our hands on the mate 20 RS porche, red version?
Read that the red version is only available in China.. But wondering if anyone knows how to get it locally, eg. Through 3rd party or online sources?
Thks!
maumu
today I was free and went to a couple of places to test the display sets @ sim lim square Huawei store and tech show.. I tried to open a white background (google search) and played with the brightness slider to change the brightness to minimum and so on.
didn't see any drastic screen bleeding but did notice a bit of a green hue glowing at the curved sides. not sure if it's my eyes playing tricks. can't test in a completely dark environment so have to rely on the guys here to do that I guess. but at least the sets I've seen, at bright levels, they look perfectly fine.
those of you who already have the phone should really try and test it out and share your findings.
jackycar
Just tested me and my wife's Mate 20 Pro, mine is black, hers is twilight, both LG screen.
No green light bleeding edge at all.. Minimum brightness with black wallpaper.
Those with bleeding issue, are you using BOE or LG screens?
BTW tested using this wallpaper: https://i.imgur.com/NakfHv4.jpg
abhishek.agger
I think I'm gonna take my chances and get the phone despite the green screen issue. StarHub online store doesn't have stock, do you think StarHub shop in Plaza Singapura has?
s-ghost
High Honorary Member
i was thinking those display sets, they have been out for more than one week liao, and many people used them, so if got screen bleed, those phones would kena first, so maybe can find a way to check those display sets
