Huawei Mate 20
Guy84
Question: my phone will be coming in few days time.. when I get this phone, did I need to factory reset for the first time before I start to use?
:s11::s11:
ayuluv
My Google Play Services is zapping more battery than my FB, does any expert knows would any app(s) be affected if I prevent it from running in background?
Settings > Battery > App Launch > Manually manage the apps
ayuluv
hmm i tried when i off run in background it will not work for me
edit : ok it works if i do not use web whatsapp. But if i switch on web whatsapp, there will not be notification sound on my phone but counter still appears
GReddy G9 RS
Nope it doesn’t. I turned off all apps and my WhatsApp telegram etc notifications still comes in timely.
It will affect more on apps like mails.
It's happen to my mate 9 n one of the posting said have to leave it on. I try it n i never encounter delay msg anymore so for my mate 20, i just leave it on too.
Sent from HUAWEI MATE 20 using GAGT
liuhao
Honestly don't bother n limit yourself to selected type c earphones. Just use convertor n open yourself to thousands of earphones..
I was like u last time, but give up trying to look for good type c earphones. Just use the convertor, now I can use all sort of earphones cheap or expensive.
just now ordered a xiaomi anc type-c and will share the performance once i received it.
for 3.5mm i have several earphones including bose quietcomfort ANC 20. i compared them with huawei stock earphone and found huawei sound resolution is clearly higher.
i havent looked into type-c usb audio specs but i guess phone will only send raw PCM audio data to earphone. in this case, the earphone is more like an USB sound card which has its own DAC and amplifier. therefore a well designed type-c earphone can easily outperform a 3.5mm earphone. since type-c earphone is an active device, ANC or even more advanced sound processing can be easily built-in.
at this moment choice of type-c earphone is limited. but i hope big brands can make type-c earphone product soon, especially bose. i used bose quietcomfort 20 many times in flight and it worked really well. but for daily usage it's kinda troublesome due to require charging.
Searingmage
Safe to turn off google play services then?
To me, most important will be whatsapp, and no drop calls/drop sms.
liuhao
i cancelled the order of xiaomi and changed to huawei ANC earphone CM-Q3. huawei phone shall use huawei earphone meh right? lol
etjx38
Just got a call from HW, now they want to test the phone before doing replacements.. so different from what they’ve promised when they replied me via fb
elementz
I think is logical that they only replace phones which have issues.
petricnah
Of course got issue then I approach them. I*********ve even sent them a picture of my phone*********s condition. So why now flip prata?
Bro, Relax lah.. Since you said your phone have issues, just let them check lah.
etjx38
If you receive a call telling you that they will replace based o the severity of your phone, how would you feel?
As what we’ve learned, the condition of the green screen worsens over time.
So if you go down today but it’s not “serious” enough for a replacement but 5 days later, it worsens and has to be replaced. Isn’t that just a waste of time?
So many here said their service is top notch, I expected better from HW
pillowjq
Then you go back to Iphone/ other phones lor. Typical entitled mentality..
Expect ppl to just change without checking or what just cause you said so...
1982-1994
why :s11:
here's mine
I meant another user of brave browser.
Chrome consumes lots of battery.
Facebook standalone app too.
Try logging Facebook on browser instead.
I mean if you're not happy with the battery life.
MrLampa
Sibei sian just drop my phone the screen protector crack liao. Zzz 25 bucks from mobile hardware. Anyone got recommendation where can get cheap one without the black borders. Wwp got black border right
