Huawei Mate 20
deadrick
anyone tried any ANC type of USB-C earphone with m20pro/m20?
the stock huawei USB-C earphone is fine but it does not have any noise block/cancellation. hard to hear things on BUS/MRT.
i see xiaomi has an ANC USB-C earphone. anyone tried with m20pro/m20? plan to get one but worry it does not work. but i heard it does work with many non-xiaomi phone models such as pixel etc.
does xiaomi concept shop in suntec city has this earphone in display? can go down to try if it has.
Honestly don't bother n limit yourself to selected type c earphones. Just use convertor n open yourself to thousands of earphones..
I was like u last time, but give up trying to look for good type c earphones. Just use the convertor, now I can use all sort of earphones cheap or expensive.
jackycar
Works with all case? Using spigen case.
Yup! I'm using spigen rugged armour too. Works perfect.
That's why I avoided the red white mobile tempered glass cause I heard it makes the TG pop out with spigen rugged armour
lorettatay
Heard that dropguard pro case for mate 20 pro has arrived. Anyone using it?
Sent from HUAWEI Mate 20 Pro Emerald Green using GAGT
Abyssal.Xuan
Dropped my phone from the hdb chair today. Landed face down ):
But all is well. The UAG case protected it (':
jackycar
Why not just go wireless? Nowadays with BT 5.0, ANC, LDAC etc isn't the quality in discernible already?
Sony Xm3?
s-ghost
High Honorary Member
is this consider okay? :s34:
deadrick
Sony Xm3?
For me I don't want another thing to charge. Lol. But it's more convenient if don't mind charging.
So many choices now don't restrict yourself to type c earphone.
1c3_5n0w
2nd cycle non pro mate 20, 40% batt left. 8h 46min SOT. really crazy, dont know if its pie's adaptive battery and huaweis optimizations combined. my note 9 cant get anywhere close.
usage are the same as yesterdays screenshot, PES, WWE Supercard, YouTube, Snapchat
everything facebook is disabled/uninstalled to whom it may concern
Sent from LENOVO LENOVO P2A42 using GAGT
ohhaithere
Anyone knows when the last restock of the M20P was on Singtel's online store? Last I heard it was on 10 Nov that Saturday?
flyingeagles
Anyone uses dual sim and WhatsApp widget as well? I usually put WhatsApp chat widget for 2 of my sim cards on home screen in my s8+ so I can view messages from both sim card on my home screen. But for m20p I cannot seems to get the widgets display 2 different WhatsApp chats.. When I select widget only got 1 WhatsApp. I'm using the app twin for WhatsApp..
Sent from HUAWEI MATE 20 PRO using GAGT
jackycar
Sony xm3 wireless supports fast charge.. Something like 5 hrs of use from 5 mins charge or sth.
If u use ANC wired also must charge no?
